Help needed Pioneer BD-RW BDR-209M
H.lunulata
#1 Post by H.lunulata » Thu Mar 12, 2026 4:31 pm
Hi together,
i am quite new to this whole thing and while i have been using MakeMKV to rip DVDs without any issues i recently purchased a Pioneer BDR-209M impulsively.
After connecting it to my laptop and purchasing the MakeMKV license it says under the LibreDrive Information "Status: Possible, not yet enabled"
After combing through the forum i came to the conclusion that it is a firmware thing and i need to update the firmware on it,
which in theory should be possible as the current firmware is pre 2022 as indicated by the "Firmware date: 2017-12-21"
going by that information i tried to find information about how to flash the firmware but everything i have found so far is about firmware for "Drive Platform MT1959"
Maybe i misunderstand something or i am missing something important but im a bit lost now and would be grateful for any help in this.
I am also 100% comfortable with using the command line and command line based tools to fix this but i just currently do not know where to start this process.
The Whole drive information is:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.50
Serial number:
Drive platform: Pioneer RS8601
Firmware version: GENE
If someone can help me with this it would be greatly appreciated
Thanks in advance for any help and advice
Re: Help needed Pioneer BD-RW BDR-209M
#2 Post by Billycar11 » Thu Mar 12, 2026 11:36 pm
H.lunulata wrote: Thu Mar 12, 2026 4:31 pm Hi together,
OS device name: E:
Revision: 1.50
Serial number:
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
H.lunulata
#3 Post by H.lunulata » Wed Mar 18, 2026 7:16 pm
Hi everyone,
so i did a firmware upgrade/downgrade and now everything works perfectly, i can rip normal BluRays and UHD discs but there is a new problem, i have two BluRays that initially worked right after the new firmware was flashed and Libredrive was enabled, they where quite slow but readable nonetheless, then i shut the Computer and when i restarted it everything else still worked but these Two particular BluRays are no longer recognized by the Drive.
Does anyone know what the reason for this could be?
I am grateful for any help and tips on how to fix this.
#4 Post by MartyMcNuts » Wed Mar 18, 2026 10:51 pm
H.lunulata wrote: Wed Mar 18, 2026 7:16 pm Hi everyone,
Clean those discs. Even if they look clean.
H.lunulata
#5 Post by H.lunulata » Mon Mar 23, 2026 12:45 am
that is the first thing i tried, but even after cleaning them with a microfiber towel and isopropyl alcohol they still do not get recognized, and its only those two very specific discs which is the most confusing thing to me.
#6 Post by MartyMcNuts » Mon Mar 23, 2026 1:13 am
H.lunulata wrote: Mon Mar 23, 2026 12:45 am Hi,
It happens. Must be something with those discs. Try a different drive. As silly as it may sound, sometimes a drive just doesn't like certain discs or try using the disc backup function.
