How to remove empty space in MKV files?
Flare
#1 Post by Flare » Sun Mar 22, 2026 11:30 pm
First, I apologize if this has been asked before, or if this is the wrong section.
I've noticed that my MKV files are the size of the discs I ripped, and I'd like to make them smaller.
I can do this by converting to another format, but is there another way to simply remove the empty data in the file?
Re: How to remove empty space in MKV files?
#2 Post by Woodstock » Mon Mar 23, 2026 12:12 am
Have you tried tools like Handbrake to recode the files to be smaller?
"Empty space" is hard to define, because it's rarely "empty". But recoding a MKV file, as ripped from a DVD or BD, to a smaller MKV file can make it anywhere from 10% to 90% smaller at the same resolution. Typical anime gets to be about 90% smaller, although some only shrinks 50-60%. Movies depend on the resolution and how much action they have.
