ASUS SBW-06D5H-U
palmera2
ASUS SBW-06D5H-U
#1 Post by palmera2 » Sun Mar 15, 2026 7:39 am
I have a license for MakeMKV and I've been enjoying it for quite a few months for reproducing (non 4K) Blu-Ray movies. Unfortunately, I have been getting the following error for the last few weeks when trying to open a Blu-Ray disc:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0FB922C4143180D25A2E574C79980B820B1 to device 'SPTI:\Device\CdRom1'
---Repeated error several times.---
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..00E35A6E4CE9C5CE961A48B99A789FD7141 to device 'SPTI:\Device\CdRom1'
Title #01472.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00810.m2ts was skipped
---Repeated message several times with different title numbers.---
I have tried updating both VLC and MakeMKV as well as uninstalling and installing again the latter. I have also deleted the .MakeMKV/_private_data folder. Neither of the two solved my problem.
The physical drive functions properly when using PowerDVD (trial version) and I am able to playback movies. I was able to open the movie I used for testing with MakeMKV a few months ago.
Thank you in advance for your comments!
This is the info I get from MakeMKV:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number:
Firmware date: 2023-04-20
Highest AACS version: 63
Drive platform: RS8511
Firmware version: E102/ID26
Disc Information
Label: THE_LAST_JEDI
Timestamp: 2018-02-07 12:43:48
Protection: AACS v63
Data capacity: 43.84 Gb
Disc type: BD-ROM
Number of layers: 2
NightPurr
Re: ASUS SBW-06D5H-U
#2 Post by NightPurr » Thu Mar 19, 2026 6:52 pm
Hi!
Here exactly the same. Same drive, same firmware - but since an MakeMKV update in summer 2025.
I had to disable LibreDrive for it to work again.
My steps (Windows) with only one drive plugged:
- close MakeMKV
- regedit
- HKEY_CURRENT_USER -> Software -> MakeMKV
- look for a entry called "speed_ASUS_SBW-06D5H-U_E102_CGDL274092WL" (in my case) - and double click on it
- copy the string without "speed_" -> In my case the string is called "ASUS_SBW-06D5H-U_E102_CGDL274092WL"
- close popup
- doubleklick on the entry called "sdf_Stop". If you don't have an entry like this - create it with type "String" (here in german its called "Zeichenfolge")
- paste your drive-string in the entry "sdf_Stop"
- close regedit
- start MakeMKV -> now LibreDrive should be disabled
- with the latest MakeMKV Update 1.18.3 and testing if LibreDrive works (it does not...), i had to unplug the drive, insert another bluray - before these steps MakeMKV gave me the same errors as with LibreDrive enabled. Maybe you have to restart the pc - give it a try and it will work again ;-)
Good luck - and lets hope we get a solution for LibreDrive to work properly on our drive.
muzza
#3 Post by muzza » Sun Mar 22, 2026 7:48 pm
Hi all,
just saw this thread as I have a similar story to OP. Working on a MacBook 2025, and getting the following error message which I've never seen before:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/B96BB03F'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..05622B7BCFAAEF66076CCB7F8D62BC570CE to device 'IoKit:/IOBDServices/B96BB03F'
my blu ray player is an ASUS SBW-06D5H-U E102 DDDL291895WL - I am a complete luddite when it comes to these things, but have some albums I'd like to rip. any Mac specific advice would be greatly appreciated.
thank you!
#4 Post by Billycar11 » Sun Mar 22, 2026 11:20 pm
muzza wrote: Sun Mar 22, 2026 7:48 pm Hi all,
thank you!
Could be a lot of things
Try giving the drive more power with higher power USB ports or a powered USB hub
muzza
#5 Post by muzza » Mon Mar 23, 2026 7:23 am
Thanks for the reply, will give it a go.
palmera2
#6 Post by palmera2 » Mon May 11, 2026 4:55 pm
NightPurr wrote: Thu Mar 19, 2026 6:52 pm Hi!
- close MakeMKV
- regedit
- close popup
- close regedit
Sorry for the late reply, works perfectly now!! I don't know how you managed to get such an elaborate and specific set of steps, but I'm glad you did.
Thanks once again!
