Help with flashing CA02 BU40N
risinghotwinds
Post by risinghotwinds »
I'm hoping to get some help flashing an LG BU40N that comes from a JOYIN-BURN Amazon listing. It has the 7+6 SATA port on the back and I got a USB cable for it.
The drive originally reported having CA02 firmware (the sticker on the drive says SW22, manufactured Nov 2022).
I attempted to flash the 1.03 MK firmware using SDFtool Flasher, but ran into issues.
I inserted a standard Blu-ray and MakeMKV reads the disc and AACS info perfectly.
SDF Flasher GUI v1.3.6 says my drive is not MT1959 so it can't flash and the recover mode is grayed out.
I tried forcing it via makemkvcon using the enc and -t mtk19xx flags (and even manually forcing the sdf.bin file). This resulted in a payload rejection: Write DRAM NG 00/00/00 and Command produced error code 0x82000000.
From reading past threads, it looks like this CA02 firmware has a hard downgrade block.
I tried flashing DE_flash_HL-DT-ST_BD-RE_BU40N_BU10 and HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 but I get errors. I think I'm supposed to flash firmware that is slim drive specific which I thought I was already doing?
Re: Help with flashing CA02 BU40N
risinghotwinds wrote: Sun Mar 22, 2026 2:01 am I'm hoping to get some help flashing an LG BU40N that comes from a JOYIN-BURN Amazon listing. It has the 7+6 SATA port on the back and I got a USB cable for it.
the problem is your case or adapter
theirs really no good slim cases available retail now
get one of the recommended full size adapters with a slim sata adapter for your drive
risinghotwinds
Billycar11 wrote: Sun Mar 22, 2026 4:52 am
I'll do that. I appreciate it.
jetfire13
Post by jetfire13 »
I got one of those slim sata LG BU40N drives from Amazon delivered today and I have an OWC enclosure that I was using for a full sized internal drive previously. What exact adapter to I need to purchase to convert the power and sata inside the OWC enclosure for the slim sata BU40N drive? I purchased one of those ICY DOCK adapters also so it will fit nicely in the bigger case. I just was concerned that the power being provided by the larger case would be an issue for the smaller BU40N drive.
Just wanted to get a definitive gameplan and necessary parts needed for this setup.
Thanks!!
jetfire13 wrote: Tue Apr 07, 2026 11:48 pm
Thanks!!
https://www.newegg.com/icy-dock-mb343sp ... -_-Product
and you may need this depending on if your sata connector is joined or not https://www.amazon.com/ChenYang-slimlin ... B00S6H54PK
jetfire13
Post by jetfire13 »
Billycar11 wrote: Wed Apr 08, 2026 4:54 am
Thanks!!
Awesome! All necessary part have been ordered. Thank you so much for your help! I really appreciate it.
