Using MakeMKV 1.18.3 Beta, seems I am unable to rip any UHD discs. I've tried three so far, including one I ripped previously with the same hardware. Bluray rips OK.
Product: BD-RE BU40N
Revision: 1.03
Serial number: ************
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: CLOSE_ENCOUNTERS_OF_3RD_KIND
Timestamp: 2017-08-09 23:39:51
Protection: AACS2.0/C v61
Data capacity: 93.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
...this disc was ripped before.
Log output:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
Saved AACS dump file as C:/Users/j/.MakeMKV/MKB20_v61_Close_Encounters_of_the_Third_Kind_40th_Anniversary_Edition_5FB5.tgz
I have a KEYDB.cfg downloaded today. If drive is in LibreDrive mode the AACS host certificate should not be revokable, correct?
I can send the dump files if that is helpful, but at least one of the problem discs is already in the KEYDB.cfg.
Suggestions?
UHD rips failing
Re: UHD rips failing
Sometimes it says libredrive is enabled even though it actually isn't or didn't start libredrive mode correctly. Try powering off the drive and/or PC for a minute or two before turning it back on.wasteram wrote: Mon Mar 02, 2026 1:05 am Using MakeMKV 1.18.3 Beta, seems I am unable to rip any UHD discs. I've tried three so far, including one I ripped previously with the same hardware. Bluray rips OK.
Revision: 1.03
Disc Information
Number of layers: 3
Log output:
Suggestions?
When libredrive is functioning correctly, any certificate revocation is ignored. It can still be revoked but MakeMKV doesn't care.
Tried that; no change.
Is there another test I can do to confirm/deny LibreDrive is active?
Any value in re-flashing the drive?
looks like a power issue again or a bad casewasteram wrote: Wed Mar 18, 2026 3:43 pm Tried that; no change.
try a higher power usb port or a powered usb hub
Nailed it! Switched the drive to direct via SATA, powered off the PC power supply. Works perfectly.
Off to find buy one of the recommended USB-SATA enclosures...
