EventDriven
Post
by EventDriven » Fri Mar 20, 2026 4:34 pm
Is anyone else having issues ripping the Lionsgate 4k "The Substitute"? It gets to 170.3M and then just hangs. I let it sit for awhile but it never actually errors out, it just stops ripping. I do have some av sync issues. I've tried to rip it live and from a backup as well using multiple drives. Wondering if anyone else has run into this?
AV synchronization issues were found in file 'C:/.../The Substitute (1996)/The Substitute (1996).mkv' (title #3)
AV sync issue in stream 0 at 0:01:31.800 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.800 : secondary stream video frame timecode differs by +83.322ms
AV sync issue in stream 0 at 0:01:31.966 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.966 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:31.966 : secondary stream video frame timecode differs by +125.033ms
AV sync issue in stream 0 at 0:01:32.133 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.133 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.133 : secondary stream video frame timecode differs by +83.321ms
AV sync issue in stream 0 at 0:01:32.300 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.300 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.300 : secondary stream video frame timecode differs by +83.321ms
AV sync issue in stream 0 at 0:01:32.467 : video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.467 : secondary stream video frame timecode differs by -0.1ms
AV sync issue in stream 0 at 0:01:32.467 : secondary stream video frame timecode differs by +83.321ms
Christmazz
Post
by Christmazz » Fri Mar 20, 2026 6:17 pm
Same here and in the exact same spot. I got around this by making a decrypted backup then using MKVToolNix to create the MKV. You'll need to rip the Blu-ray to MKV then "add as new source files" into MKVToolNix and deselecting everything from the Blu-ray except the chapters if you want chapters in the final MKV.
EventDriven
Post
by EventDriven » Sat Mar 21, 2026 7:18 pm
Christmazz wrote: ↑Fri Mar 20, 2026 6:17 pm
Hey thanks, that worked perfectly! Hadn't used MkvToolNix for that before so good to get another technique to add to the tool chest. Much appreciated!
