DVD Drive Question
Alriightyman
DVD Drive Question
#1 Post by Alriightyman » Sat Mar 21, 2026 5:36 pm
I understand that for bluray ripping, you need to be selective about the drive you use. What about DVD drives though? Can I pick up any dvd drive and use it with MakeMkv? I have a good deal of DVDs and don't really want to use my BD to rip them.
Also, I wasn't sure where to post this. Sorry if this is the wrong place.
Re: DVD Drive Question
#2 Post by dcoke22 » Sun Mar 22, 2026 4:07 am
Generally speaking MakeMKV will work with most any DVD drive. It isn't guaranteed to work with every drive nor in every scenario. For instance, MakeMKV might be able to make a DVD drive rip a disc with a different region code than the drive is set to, but it might not.
If you've got a DVD drive gathering dust somewhere it is definitely worth plugging it in and trying to use it. If buying used the price should be low enough that a broken drive or one that MakeMKV can't use shouldn't be much of a financial burden.
Alriightyman
#3 Post by Alriightyman » Mon Mar 23, 2026 12:15 pm
Thanks. I picked up a cheap $20 dvd drive. Seems to be working well. I do have some old ancient drives from early 2000s, I'd need to find a compatible enclosure for it. I'll look into it after the dvd drive fails.
