Convert mkv with DV dvhe.08.06 (BL+RPU) into BluRay format (?)
Hot_T
Post by Hot_T » Wed May 04, 2022 4:46 pm
I have a problem converting an mkv with dolby vision back to BluRay format.
The mkv contains a video layer with integrated RPU information (dvhe.08.06 BL+RPU).
Using tsMuxer for creating a bluRay folder structure, the end result is not playble.
I think BluRay needs to have two layers for DV. Otherwise it's not compatible (?)
I managed to remove the RPU information to get a clean BL hevc-file (dovi_tool).
With this cleaned video stream I can use tsMuxer to create a BluRay folder structure which is playble.
But this way I am losing the HDR information within the RPU.
Has anyone achieved to create a BluRay video including the RPU information?
Must the RPU be converted into a MEL format? If yes, how to achieve this?
Any help is appreciated, thanks in advance!
joseluko
Re: Convert mkv with DV dvhe.08.06 (BL+RPU) into BluRay format (?)
Post by joseluko » Fri Mar 20, 2026 5:57 pm
Hot_T wrote: Wed May 04, 2022 4:46 pm Hello,
I know this thread is quite old, but I am currently facing exactly the same issue.
Since some time has passed, I was wondering if there has been any new solution or workaround for this problem.
Thank you very much.
Post by Coopervid » Fri Mar 20, 2026 6:46 pm
joseluko wrote: Fri Mar 20, 2026 5:57 pm
Here is a guide but its fairly old and based on an older version of DVDFab.
https://mega.nz/folder/SZgFDD5a#GtZ7FaAhWQHMoLrhQsgsnw
