farmboy
#3706 Post by farmboy » Thu Mar 19, 2026 3:55 am
Billycar11 wrote: Thu Mar 19, 2026 3:41 am
farmboy wrote: Thu Mar 19, 2026 3:07 am
still having an error. switched to a desktop so there is better power available. Got it so it doesn't randomly disconnect. But will still fail. Screenshot below. There is an error that comes up about "downloading latest HK disabled or failed". Not sure if that is relevant? 1st time it tried to download that, it just sat there a while and failed.
you still likely have a power issue if the dive is showing no disc in the middle of trying to open it
try a high powered usb hub 35+ watts
oh wait your on linux downgrade to 1.00 then try again
no luck on 1.00 either.
Going to walk away from this tonight.
So, what is a recomended external drive for ripping 4K UHD movies?
#3707 Post by Billycar11 » Thu Mar 19, 2026 7:47 am
farmboy wrote: Thu Mar 19, 2026 3:55 am
no problem
i only recommend pioneers but they are near impossible to find at a reasonable price my favorite drive is the xd08b/s/g
never get the tc one thats fake.
you still may have a power issue as is disconnecting right away right at 0 get your self a high powered usb hub 35+ watts and try again
defiantly do not get the archgon as for now it does not work for flashing or reading in the case
babayaga
#3708 Post by babayaga » Sat Mar 21, 2026 5:50 am
It seems now that the new verbatim slim drives are now using LG in northern Europe as well, this was bought two weeks ago (21/3-26).
Product: BD-RE BU40N
Revision: 1.05
Serial number: .........
at least it can be flashed :)
#3709 Post by MartyMcNuts » Sat Mar 21, 2026 6:11 am
babayaga wrote: Sat Mar 21, 2026 5:50 am It seems now that the new verbatim slim drives are now using LG in northern Europe as well, this was bought two weeks ago (21/3-26).
Revision: 1.05
I think all Verbatim models have been LG BU40N drives since mid 2025, except the 43887 which still contains a Pioneer BDR-UD03 (who knows for how long!) that can be cross-flashed to BDR-UD04 firmware for UHD compatibility.
videogameguru
#3710 Post by videogameguru » Mon Mar 23, 2026 1:37 am
Hey everyone I'm sorry to double post but I don't believe my previous post was seen. I'd really appreciate an answer please.
videogameguru wrote: Tue Mar 17, 2026 2:07 am Hey everyone! I was looking on the front page and noticed that there's a bunch of new firmwares since I flashed my LG WH16NS60 7 odd years ago. Its on version 1.01. is there any reason for me to update it? If so am I safe to do so without risk of bricking? These units are long discontinued now and I'd hate to ruin an otherwise perfectly running drive. Thanks!
#3711 Post by MartyMcNuts » Mon Mar 23, 2026 2:15 am
videogameguru wrote: Mon Mar 23, 2026 1:37 am Hey everyone I'm sorry to double post but I don't believe my previous post was seen. I'd really appreciate an answer please.
Why would you want to? There's no benefit. If it works, leave it alone.
videogameguru
#3712 Post by videogameguru » Mon Mar 23, 2026 2:18 am
MartyMcNuts wrote: Mon Mar 23, 2026 2:15 am
I wasn't sure if there was under the hood changes that improved things possibly. It works great as is just figured I'd see if there's any reason to flash a newer firmware. But if the experts don't believe it's necessary I won't worry about it.
farmboy
#3713 Post by farmboy » Fri Mar 27, 2026 10:49 pm
nicholfd wrote: Thu Mar 19, 2026 3:41 am "HK Download" error - MakeMKV needs internet access to download keys. It is enabled by default. Check internet or confirm setting in MakeMKV allows Internet access. I *think* some downloads are from Russia(?) - make sure your FW/router is not blocking Regional IP addresses.
Download failure is not related to the SCSI error messages - those are still power related.
Desktop does not necessarily equal better power.
Use a "Y" cable w/2 x USB port connections, AC adapter (if chassis supports it), or a good, high amp output USB hub.
can you point to a specific "Y" cable?
I've tried a few different types, but the ones I've gotten only allow power and data from the side with 1 connection (Side A) to either cable on the two cable side (Side B). Meaning that I cannot connect the the drive to side A, and have one cable on side B go to the computer and the other go to my 65W output USB-C. The power won't go from side B to side A. And it appears to be isolated so I can't send power across the two side B cables.
(hopefully this makes sense). I'm not finding a way to supply power AND data to the drive via two different sources.
nicholfd
#3714 Post by nicholfd » Fri Mar 27, 2026 10:58 pm
farmboy wrote: Fri Mar 27, 2026 10:49 pm
The "Y" cables have "specific" ends. Here is a 2 x USB-A -> USB-C cable I've used & include with my Verbatim drives I have for sale: cablecc USB-C Male & USB 2.0 Dual Power Data Y Cable for Laptop & Hard Disk.
The thinner cabled USB-A is power only. The thicker USB-A is power & data. The USB-C end is for the drive, and you'd have to buy a "Y" cable with the same connector type on this end, to match what is on your USB chassis/drive (I don't recall if you listed what is on your USB drive chassis). The above linked cable has options on the product page for various chassis/drive ends of the cable.
Simmr
#3715 Post by Simmr » Sun Mar 29, 2026 9:57 am
Thanks for the extensive guide and provided ressources. I've been using MakeMKV for some years now and it's been great.
Some time ago I patched my drive (BP55EB40) but just now got my hands on a UHD disk to try ripping that. The drive is searching the disk for about 2 minutes and then MakeMKV shows no disk inserted.
Is this related to the sleep error? How can I fix this?
The screenshot is from Linux but I am experiencing the same behavior on Windows and with another disc too. FHD Blu rays can be ripped without any problem at up to 6x speeds from what I've seen so far.
Thanks in advance!
The same error exists on Win11
Maskman
#3716 Post by Maskman » Sun Mar 29, 2026 10:15 pm
Which firmware for the ASUS BW-16D1H-U PRO please ? I also have issue with Nero Burning rom (a better software ?) which doesn’t detect my device :? maybe need a driver I don’t have, just the default Windows one.
Thanks.
#3717 Post by Billycar11 » Mon Mar 30, 2026 1:51 am
Maskman wrote: Sun Mar 29, 2026 10:15 pm Hi,
Thanks.
Flash to wh16ns60
Viscous5182
#3718 Post by Viscous5182 » Mon Mar 30, 2026 6:38 pm
Billycar11 wrote: Mon Mar 30, 2026 1:51 am
Thanks.
Flash to wh16ns60
Hello, Im also considering to buy an Asus BW-16D1HT, specifically:
Model: BW-16D1HT
Complete model name: BW-16D1HT/BLK/B/AS
Manufacture date: July 2016
Model P/N: 90DD0200 - B30000
I would like to know if it's possible to make it able to rip UHD blu-rays while maintaining the ability to burn bluray discs, as I've read in the guide:
In some cases crossflashing an Asus drive to an LG or the other way around you may no longer be able to burn disks-SamuriHL
If that reveals possible what would be the best "firmware path" to follow?
Maskman
#3719 Post by Maskman » Mon Mar 30, 2026 10:18 pm
Thanks.
Flash to wh16ns60
Thanks ! Which version please ? There is different versions of wh16ns60.
#3720 Post by Billycar11 » Mon Mar 30, 2026 10:49 pm
Maskman wrote: Mon Mar 30, 2026 10:18 pm
Thanks.
Flash to wh16ns60
I recommend 1.02 or 1.00
