AACS v20, BD+ 2012.2.
I am able to rip all the supplements, but the movie rip fails quickly (failed to save title 0).
I am using a Pioneer BDR-XD04 with firmware 1.1 on a MacBook Air running 10.7.3.
Haven't any problems with other disks. Downloaded the dsall.svq.
We bought a zoo
setarip_old
Re: We bought a zoo
Hi!
This is a brand new 20th Century Fox release. Very likely a new version of "BD+". Click on the link to submit the SVQ...
DanaK4LK
Re: We bought a zoo
Hi, I'm new to this. What do I do?setarip_old wrote:Hi!
This is a brand new 20th Century Fox release. Click on the link to submit the SVQ...
DanaK4LK
Re: We bought a zoo
I think I figured it out from http://www.makemkv.com/svq/DanaK4LK wrote:Hi, I'm new to this. What do I do?setarip_old wrote:Hi!
I'll have it create the BD+ dump and send it later.
Re: We bought a zoo
Still an old pre-Sitter version, SVQ file updated.
DanaK4LK
Re: We bought a zoo
Thanks Mike,mike admin wrote:Still an old pre-Sitter version, SVQ file updated.
The rip almost finishes, but I get a MEDIUM ERROR on 00500.m2ts at offset 23561238528
Makes me wonder if the disk is defective. Guess I'll try watching the movie in my home theater.
Dana
setarip_old
Re: We bought a zoo
Now that the SVQ has been updated, try cleaning the disc and re-ripping...
DanaK4LK
Re: We bought a zoo
Great. Will try again tonight. Thanks.setarip_old wrote:Now that the SVQ has been updated, try cleaning the disc and re-ripping...
DanaK4LK
Re: We bought a zoo
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '23521062912'setarip_old wrote:Now that the SVQ has been updated, try cleaning the disc and re-ripping...
This disk is a replacement. The first copy wasn't reporting media errors. I have the Pioneer BDR-XD04 v1.10 on a MacBook Pro running 10.7.3. Haven't had any problems ripping any other title.
BlackDragon24
Re: We bought a zoo
Someone will have to correct me if I'm wrong, but that usually means an error with the disc itself (scratch, smudge, bad pressing) or a drive not working properly.DanaK4LK wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '23521062912'setarip_old wrote:Now that the SVQ has been updated, try cleaning the disc and re-ripping...
Occasionally I will get a blu-ray that just doesn't like my drive. I had to go through 4 box sets of HBO's Rome before I found a pressing that played well with my player. It was a major PITA. I don't know if that's what's happening here.
DanaK4LK
Re: We bought a zoo
Watched the movie and supplements in my home theater. No problems. ConfusedBlackDragon24 wrote:Someone will have to correct me if I'm wrong, but that usually means an error with the disc itself (scratch, smudge, bad pressing) or a drive not working properly.DanaK4LK wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '23521062912'setarip_old wrote:Now that the SVQ has been updated, try cleaning the disc and re-ripping...
BlackDragon24
Re: We bought a zoo
Your home theatre isn't trying to make a bit by bit copy the way makemkv is.DanaK4LK wrote:
trez99
Re: We bought a zoo
Anyone else having trouble with this one or is it just me ...
003338:0000 Downloading latest SVQ(s) to C:/ ...
003317:0000 Loaded 24 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00003.svq
001003:0020 DEBUG: Code 0 at t4y^-,XL6YxgjGvB:29400531
001003:0020 DEBUG: Code 0 at t4y^-,XL6YxgjGvB:29398254
001003:0020 DEBUG: Code 0 at t4y^-,XL6YxgjGvB:213139690
003325:0000 Failed to process BD+ code using generic SVQ from builtin/00003.svq
003324:0000 Processing BD+ code using generic SVQ from builtin/00002.svq
Trez
Trez
hetch6
Re: We bought a zoo
Still having issues with this disk. I've tried downloading the dsall.svq with no luck.
I see the line that says it's processing using the generic SVQ and wonder if that's right and that it should be using the Disc Specific SVQ in the dsall.svq file.
Any ideas?
MakeMKV v1.7.4 linux(x64-release) started
Downloading latest SVQ(s) to /home/carl/.MakeMKV ...
Loaded 33 SVQ file(s)
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /home/carl/.MakeMKV/dump_We_Bought_A_Zoo_9257E89451F74A86.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Failed to open discAny ideas?
crowfax
Re: We bought a zoo
Send the dump file here:
to support@makemkv.com
/home/carl/.MakeMKV/dump_We_Bought_A_Zoo_9257E89451F74A86.tgzHome Theater PC: Assassin HTPC, XBMCbuntu 12.0 (Frodo), Intel i5 3570k 3.4 GHz Ivy Bridge w/ HD 4000, LG BD-ROM
