Flashing Verbatim 43888 from Linux
simland
Post by simland »
Hi, just got the 43888 and have not been able to flash from Linux (I don't have anything with Windows). When I use makemkvcon from the shell there is simply no response at all to the flash command. Other commands do work.
I am using PopOS which is Ubuntu based. I usually used the MakeMKV flatpak which works just fine. I have also downloaded the src/bin and built/installed with no problems. I got the 'The all you need firmware pack.zip'.
When I plug it in:
[101498.475361] usb 2-1: new SuperSpeed USB device number 6 using xhci_hcd
[101498.491095] usb 2-1: New USB device found, idVendor=18a5, idProduct=0428, bcdDevice= 1.cd
[101498.491114] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[101498.491123] usb 2-1: Product: Verbatim 4K BD RW
[101498.491130] usb 2-1: Manufacturer: Verbatim
[101498.491137] usb 2-1: SerialNumber: 0025084C09D5
[101498.493448] usb-storage 2-1:1.0: USB Mass Storage device detected
[101498.494750] scsi host4: usb-storage 2-1:1.0
[101499.556499] scsi 4:0:0:0: CD-ROM            HL-DT-ST BD-RE BU40N      1.05 PQ: 0 ANSI: 0
[101499.559299] sr 4:0:0:0: Power-on or device reset occurred
[101499.564676] sr 4:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[101499.572408] sr 4:0:0:0: Attached scsi CD-ROM sr0
[101499.572618] sr 4:0:0:0: Attached scsi generic sg1 type 5
$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MO1P7JI5138
   makemkvcon f -d /dev/sr0 --info
SDF.bin version: 0x00A5
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N     1.05:N000300:-
As far as I can tell I should be flashing like this:
makemkvcon f --all-yes -d /dev/sr0 rawflash enc -i ./HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Am I doing something wrong?
Thanks for any advice.
Re: Flashing Verbatim 43888 from Linux
simland wrote:
Wed Mar 18, 2026 6:57 pm
When I plug it in:
$ makemkvcon f -l
Found 1 drives(s)
8013:Status
8001:Drive platform
:MT1959
For Linux flashing, use an older version. Nothing newer than v1.17.7
Also make sure to go down to 1.00 after mk
simland
Post by simland »
Thanks,
I found the old versions here (in case anyone else is looking): makemkv.com/download/old
I successfully flashed with:
makemkvcon f -d'dev_21:1' -f ./sdf.bin rawflash slim,enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
simland wrote:
Fri Mar 20, 2026 5:34 pm
Thanks,
Now flash down to BU40N 1.00 for use on Linux.
