Issues backing BD
Ginger14
Issues backing BD
Post by Ginger14 »
I’ve been searching through the forums but haven’t been able to find a solution—apologies if I missed an existing post. If you can point me in the right direction, I’d really appreciate it.
I’m trying to back up the Avatar Blu-ray, but I’m running into the errors listed below. I downloaded and added the KEYDB.cfg file to the .MakeMKV folder, but the issue persists. I’ve just started backing up my DVD and Blu-ray collection, and this is the first title giving me trouble. I have a feeling I may run into similar issues with other discs, but so far this is the only one causing problems. Let me know if I can provide anymore information to help.
Thanks in advance for any help!
Failed to get BD disc information, reporting double-layer BD-ROM to BD+ code
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDSVM/00000.svm' at offset '0'
BD+ dump directory is not accessible, BD+ dump not saved
Product: BD-RE BU40N
Revision: 1.03
Serial number: SIK0DQ1994114
Highest AACS version: 31
Firmware version: 1.03
Disc Information
Label: RED_BIRD_2D_WW
Timestamp: 2010-03-11 12:01:05
Protection: AACS v16, BD+ v2010.3
Data capacity: 46.61 Gb
Disc type: BD-ROM
Number of layers: 2
Re: Issues backing BD
How is your drive powered? Via 2 USB plugs? If so make sure they're both plugged into high powered USB ports either via a powered hub or via ports on your motherboard (not front-of-case ports, which are rarely 'high powered' ports).
Your error looks like LibreDrive wasn't enabled on your drive when trying to rip a disc. That might be because it wasn't getting enough power. It might mean your drive needs to be unplugged so it can be powered cycled before you try again.
