PIONEER BDR-209M with 2015 firmware UHD possible?
Cheesemaster64
Post by Cheesemaster64 »
Hi
Since this is a pre-2017 drive with an unlocked bootloader, I am looking to perform a DIY cross-flash to enable UHD support (likely to the BDR-S11/211 series).
Can anyone provide—or point me toward—the raw .bin files (specifically the S11/211 kernel and firmware) and
the appropriate flashing utility (DVRFlash or the patched Pioneer flasher) required for this specific RS8600 cross-flash?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.33
Serial number: PADL046421WL
Firmware date: 2015-12-09
Highest AACS version: 25
Drive platform: RS8600
Firmware version: 1.33
Disc Information
Label: ET_DOM
Timestamp: 2012-08-08 09:26:50
Protection: AACS v25
Data capacity: 43.17 Gb
Disc type: BD-ROM
Number of layers: 2
Re: PIONEER BDR-209M with 2015 firmware UHD possible?
Cheesemaster64 wrote: Wed Mar 18, 2026 10:51 am Hi
OS device name: E:
Revision: 1.33
Disc Information
Label: ET_DOM
Disc type: BD-ROM
Number of layers: 2
PM sent.
