Is there any difference between the UD03 and UD04 or are they the same drive ?
Is that why you can crossflash them ?
And if you have a UHD enabled firmware is there any change to that compared to original firmware in terms of writing quality to media or reading discs etc, other than you can read UHD discs with makemkv that you can not do with original firmware ?
You do not ship to Europe ?
I can still get LG BP55EB50 slim drives, I think there is at least 50-100 devices but I would have to drive around where I am at to every store and buy them, patch and resell them, not something i want to do. I can also buy Verbatim drives from one place here, 13 in stock right now, don't know where they source them from. Somewhere in Europe I guess.
NEW Single Drive Flasher - available worldwide!!
DennisOlof
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
The only real difference is the UD04 is a UHD drive so includes the AACS 2 chip.DennisOlof wrote: Mon Feb 02, 2026 4:03 pm Is there any difference between the UD03 and UD04 or are they the same drive ?
They are cross-flashed with Pioneer original firmware, just firmware from the UHD (UD04) model.
I do ship to some European countries.
DennisOlof
@MartyMcNuts nice. I will get back to you late this week or next week. I want a Verbatim case with a UD03 and I can accept that shipping could cost me up to 100 euros depending on what typ and how fast.
Speed is not essential but rather to get my hands on a genuine unit. I also manage to find out that the Verbatim case has a VLI (VIA Technologies) SATA to USB bridge chip, at least most cases should have that chip and it seem people are saying it is a good stable chip to use with operating systems. A bad SATA-to-USB bridge chip typically causes issues like drives not being detected, intermittent disconnections, slow file transfers, or data corruption etc. I have had issues with Jmicron chips but my other Ascom (asus) chip is still solid as a rock, worked perfect with Win7 and Win10.
Anyway the verbatim drive can be removed and used with SATA, this is not possible with the slim drive pioneer models.
Stock levels updated in first post.
All Pioneer branded drives are now gone! There will be no more. I do still have some Verbatim 43887's with the Pioneer BDR-UD03 cross-flashed to BDR-UD04 firmware for UHD compatibility available. This is now the only drive available.
I'll keep trying to source some Verbatim 43888's with the LG BU40N inside but it isn't looking good.
All Pioneer branded drives are now gone! There will be no more. I do still have some Verbatim 43887's with the Pioneer BDR-UD03 cross-flashed to BDR-UD04 firmware for UHD compatibility available. This is the only drive currently available.
I'll keep trying to source some Verbatim 43888's & 43889's with the LG BU40N inside and update this thread if I get some.
I have very limited stock of the Verbatim 43888's & 43889's with the LG BU40N available.
I have very limited stock of the Verbatim 43888's & 43889's with the LG BU40N available. I will continue trying to source some but may not be able to get any more.
I also have a few of the LG BP50NB40 cross-flashed to LG BU40N firmware available.
I have one Verbatim 43889 with the LG BU40N available. I will continue trying to source some but may not be able to get any more.
I have some of the Xrtfore F03 flashed with BU40N firmware available.
I have some Verbatim 43887's with the Pioneer BDR-UD03 cross-flashed to BDR-UD04 firmware for UHD compatibility available.
I have a few Verbatim 43888's coming soon.
Re: NEW Single Drive Flasher - available worldwide!!
NEW Single Drive Flasher is now available:
A fast, reliable Windows tool for flashing optical drives using the MT1959 drive platform, with a clean interface and secure licence activation. The tool clearly shows you the recommended version for your chosen drive and also other available firmware versions. Choose whichever version you want. You also have the option to change the firmware version at anytime, if you prefer to use a different one.
Each purchase includes an instant download and a unique licence key delivered at checkout.
* NEW Single Drive Flasher * available to purchase at https://payhip.com/b/MyeJ9
Requirements are:
As far as drives go, I have 2 x Xrtfore F03's flashed with BU40N 1.00 firmware for UHD readability available.
I am still waiting on a few Verbatim 43888's. Not sure what's happening there and I may not actually get them at all.
Requirements are:
- Windows 11 PC (64 bit)
Sayaka
I've just purchased a flasher and the activation was successful. Thank you for this !
To clarify, this should work with any flashable MT1959 drive, yes ? Including a BU50N ?
Yes, as long as the drive meets the usual criteria:Sayaka wrote: Sat Jul 04, 2026 6:36 am I've just purchased a flasher and the activation was successful. Thank you for this !
- Manufactured from 2016+
- uses the MT1959 drive platform
- Has a compatible SVC code (not NB71 or the early NB40 codes)
But yeah, the BU50N can be flashed with the BU40N firmware.
Sayaka
Thank you. I am planning on trying your flasher on that odd WBacon drive with a BU50N inside (assuming I can get my hands on one eventually) should I have issues flashing it the normal way.
