Dump File for Rush's Grace Under Pressure (Super Deluxe)
OwenGwilliam
Post by OwenGwilliam »
Attached the TGZ file for the Blu-ray included in the new reissue of Rush's Grace Under Pressure album. Thanks so much!
MKB_v82_RUSH_-_Grace_Under_Pressure_0B94.tgz
(194.74 KiB) Downloaded 625 times
Re: Dump File for Rush's Grace Under Pressure (Super Deluxe)
Did you also email the file to svq@makemkv.com, so that it can be incorporated into MakeMKV?
OwenGwilliam
Sigh. No. And I knew better too.
Just sent it now. Thanks so much for the reminder!!
