Removed Cells
floatinjoe
Removed Cells
Post by floatinjoe »
I tried to rip Have Gun Will Travel - Season 6 Volume 1 - Discs 1 & 2. I didn't notice it when I first ripped the discs, but the only thing that ripped were the opening credits for each episode. I put the discs back in and noticed that a number of cells were being removed from all the episode titles. I opened the discs manually and they ripped without a problem.
What would cause this? Also, is there a way to prevent MakeMKV from removing cells in the future?
As a note, it didn't do this to any of the other 33 discs in the boxset.
Title #1 was added (1 cell(s), 0:00:16)
Title #2 was added (1 cell(s), 0:00:05)
Cells 2-6 were removed from title end
Title #5 was added (1 cell(s), 0:00:27)
Title #6 was added (1 cell(s), 0:00:28)
Title #7 was added (1 cell(s), 0:00:26)
Title #8 was added (1 cell(s), 0:00:27)
Title #9 was added (1 cell(s), 0:00:27)
Title #10 was added (1 cell(s), 0:00:26)
Title #11 was added (1 cell(s), 0:00:27)
Title #12 was added (1 cell(s), 0:00:26)
Cells 2-47 were removed from title end
Title #13 was added (1 cell(s), 0:00:27)
Title #13 in VTS 3 is equal to title #05 and was skipped
Re: Removed Cells
There are different DVD Opening Modes you could try.
floatinjoe
Re: Removed Cells
Thank you. I am using the "Auto" setting. I managed to get it to work by opening the disc manually, but I'll try the other settings if I encounter this again.
