Region Setting of Drive does not match region of disc
GKDTheGuy
Post by GKDTheGuy » Sat Mar 22, 2025 1:46 am
I just have a DVD external reader. I have a normal dvd inserted. When I try to open, I just get the error saying "Region setting of Drive does not match region of disc". I am using a LG DVDRAM SP80NB80. Any help would be appreciated!
BrettTheRipper
Re: Region Setting of Drive does not match region of disc
Post by BrettTheRipper » Fri Mar 28, 2025 12:23 am
It sounds like your optical drive is DRM locked into a region that's different from the disk's region. I don't know if new drives still do this because it's been a long time since I last bought an optical drive I didn't flash. The last I knew of, though, there was a counter that was incremented each time you played a disk, and once that counter reached a certain number (I think it was 5), the drive would become locked into the whatever region the disk was assigned, and from then on would only play disks associated with that region. For example, if your drive became locked to Region 1 (North America), any future attempts to play disks from other regions (e.g., Region 2 / Europe & Middle East) would fail. It sounds like that's what happened here.
KaileyWaelchi
Post by KaileyWaelchi » Thu May 08, 2025 4:30 am
Press Windows + X > select Device Manage. Open the DVD/CD-ROM drives section. Switch to the DVD Region tab. Select the country corresponding to the region code of the disc you want to view
polytrack
Post by polytrack » Tue Mar 17, 2026 7:21 am
If you frequently watch DVDs from multiple regions, you shouldn't change drive regions too often. The safest solution is to use VLC or similar software.
