Provide the Makemkv info and I will send the flasher if possible to flash.higaru wrote: Thu Mar 12, 2026 5:11 pm @Coopervid - wondering if specifically the BDR-UD03FAL with a mfg. date of Jan 2017 can be flashed to read 4K UHD, and if you could kindly provide those details via PM. Thank you!
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.frosty2691 wrote: Mon Mar 09, 2026 2:07 am Good day/evening sirs, I am new and cannot send PMs, but I would like to flash my drive so that it can rip 4K BD, can anyone help me please? thanks in advance!
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Migaman
Hi CooperVid,
Are you able to assist me with the flasher for this drive:
Revision 1.14
Firmware data: 2020-06-15
Drive Platform: RS8511
Thank you in advance
Revision 1.14
PM is coming.Migaman wrote: Fri Mar 13, 2026 1:51 am Hi CooperVid,
Revision 1.14
fornax
Hi, could you please help me with the following drive:
Laufwerksinformation
OS-Gerätename: /dev/sr1
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:
Many thanks!
Produzent: PIONEER
Revision: 1.14
Serienummer:
Many thanks!
Sure email me that drive info section see below for emailfornax wrote: Sat Mar 14, 2026 4:35 pm Hi, could you please help me with the following drive:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Many thanks!![]()
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
PM sent.fornax wrote: Sat Mar 14, 2026 4:35 pm Hi, could you please help me with the following drive:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Many thanks!![]()
pondermotive
Hi, I recently got an internal pioneer drive, I'd like to backup a small collection of UHDs, my makemkv info:
OS device name: F:
Product: BD-RW BDR-209M
Revision: 1.20
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 35
Drive platform: RS8600
Firmware version: 1.20/ID60
Any help appreciated, I don't think the sdftool will do it, ty.
OS device name: F:
Revision: 1.20
Sure email me that drive info section see below for emailpondermotive wrote: Sun Mar 15, 2026 2:42 pm Hi, I recently got an internal pioneer drive, I'd like to backup a small collection of UHDs, my makemkv info:
OS device name: F:
Revision: 1.20
pondermotive
Hi Coopervid, I got your PM but don't think I have enough posts to reply. Could you send me the flasher?
emichl1
I also have a drive I want to update:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.10
Serienummer:
Firmware-Datum: 2017-04-18
Firmware version: 1.10
Keine Disk eingelegt
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.10
Serienummer:
PM sent.emichl1 wrote: Mon Mar 16, 2026 4:32 pm I also have a drive I want to update:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.10
Serienummer:
fornax
Sorry, didn't work. MakeMKV keeps searching and isn't finding anythingCoopervid wrote: Sun Mar 15, 2026 10:34 amPM sent.fornax wrote: Sat Mar 14, 2026 4:35 pm Hi, could you please help me with the following drive:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Many thanks!![]()
Post your Makemkv info after flashing. Did you follow the tutorial?fornax wrote: Mon Mar 16, 2026 5:50 pmSorry, didn't work. MakeMKV keeps searching and isn't finding anythingCoopervid wrote: Sun Mar 15, 2026 10:34 amPM sent.fornax wrote: Sat Mar 14, 2026 4:35 pm Hi, could you please help me with the following drive:
Produzent: PIONEER
Revision: 1.14
Serienummer:
Many thanks!![]()
Makar
I got lucky and bought the last Pio UD03 in the state at Staples
Revision: 1.14
Highest AACS version: 77
Revision: 1.14
