firmware for BU50N
amurorx81
firmware for BU50N
Post by amurorx81 »
Hi, I got the following BU50N drive and try to flash the firmware to enable LibreDrive. I searched the forum with 'BU50N' and went through 13 pages of search result. It seems that I should use "mk-firmware-pack-20200720\MK\HL-DT-ST\BU50N\HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin" from this page: viewtopic.php?f=19&t=19113. Am I correct? Thanks a lot!
OS device name: F:
Product: BD-RE BU50N
Revision: CH00
Serial number: *********
Firmware date: 2121-05-20 09:06
Bus encryption flags: 1F
Highest AACS version: 63
zittrig
Re: firmware for BU50N
Post by zittrig »
You can use it or flash to BU40N 1.03MK.
The BU40N and the BU50N is the same hardware. The different model names related to different distribution channels.
amurorx81
Post by amurorx81 »
zittrig wrote: Sun Mar 15, 2026 9:33 pm You can use it or flash to BU40N 1.03MK.
The BU40N and the BU50N are the same hardware. The different model names related to different distribution channels.
Thanks a lot for your reply. I used the "All You Need Firmware Pack (MartyMcNuts)\Slim External Drives\DE_LG_BU40N_1.03_MK.bin" and it works! But just curious to know whether there will be any difference between this "DE_LG_BU40N_1.03_MK.bin" and "mk-firmware-pack-20200720\MK\HL-DT-ST\BU50N\HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin"? Thanks again!
zittrig
Post by zittrig »
The BU40N / BU50N 1.00 is the original LG firmware and is nativly 4K friendly.
Advantage: You can use other tools like DVDFab also.
Disadvantage (in my opinion): The 1.03MK has less problems with difficult discs.
amurorx81
Post by amurorx81 »
zittrig wrote: Mon Mar 16, 2026 12:58 pm The BU40N / BU50N 1.00 is the original LG firmware and is nativly 4K friendly.
Thanks for your advice!
