If LibreDrive isn't supported then MakeMKV can't even do DVDs?
red-lichtie
Post by red-lichtie »
Am I understanding this correctly?
The BluRay that I have been using for years with MakeMKV is no long supported because it doesn't support 4K BluRay?
It can't do DVDs or normal BluRays anymore unless you support the hardware?
What kind of an idea is this? Why is there no backwards compatibility? Why isn't there simply a warning that new formats might/will not be supported?
Why is there such a breaking change?
Is there a way to get my old BluRay working again without resorting to 1.17.7 and never ever getting an update again?
Re: If LibreDrive isn't supported then MakeMKV can't even do DVDs?
red-lichtie wrote: Mon Mar 16, 2026 1:04 am Am I understanding this correctly?
That's not the case at all it should still work as it always did with DVDs libredrive is only needed for 4K but can also help with Blu-ray
What's the issue you are seeing post the log plain text please
keydb_helper
Post by keydb_helper »
No, you are not.
red-lichtie wrote: Mon Mar 16, 2026 1:04 am What kind of an idea is this?
The kind of idea that you seem to have conjured up yourself by severely misinterpreting several forum posts?
red-lichtie wrote: Mon Mar 16, 2026 1:04 am Why is there such a breaking change?
It isn't a breaking change - it is a regression which affects certain Linux distributions. The distinction is important.
red-lichtie wrote: Mon Mar 16, 2026 1:04 am Is there a way to get my old BluRay working again without resorting to 1.17.7 and never ever getting an update again?
My recollection is that you only have to resort to v1.17.7 temporarily and run MakeMKV once to populate your local _private_data.tar file. After the file has been successfully generated, you can upgrade to the latest version of MakeMKV and continue to use whichever piece of shit drive you happen to own.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
red-lichtie
I have found a way to get the latest version (1.18.3) working.
Edit
.MakeMKV/settings.conf
and add your drives name to "sdf_Stop",
In my case it looks like this:
sdf_Stop = "TEAC_BD-W26SS-B_2.02_{serial number}"
With that, the original functionality returns.
zaqqaz6917
Post by zaqqaz6917 »
Teac ....wow
Haven't heard that name in decades :mrgreen:
Krawk
Post by Krawk »
Most common DVD rip issue is the user forgets to set the region of the drive. Many issues arise from a region 0 drive.
