firmware for BU50N
amurorx81
firmware for BU50N
#1 Post by amurorx81 » Sun Mar 15, 2026 5:46 am
Hi, I got the following BU50N drive and try to flash the firmware to enable LibreDrive. I searched the forum with 'BU50N' and went through 13 pages of search result. It seems that I should use "mk-firmware-pack-20200720\MK\HL-DT-ST\BU50N\HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin" from this page: viewtopic.php?f=19&t=19113. Am I correct? Thanks a lot!
OS device name: F:
Product: BD-RE BU50N
Revision: CH00
Serial number: *********
Firmware date: 2121-05-20 09:06
Bus encryption flags: 1F
Highest AACS version: 63
zittrig
Re: firmware for BU50N
#2 Post by zittrig » Sun Mar 15, 2026 9:33 pm
You can use it or flash to BU40N 1.03MK.
The BU40N and the BU50N is the same hardware. The different model names related to different distribution channels.
amurorx81
#3 Post by amurorx81 » Mon Mar 16, 2026 3:25 am
zittrig wrote: Sun Mar 15, 2026 9:33 pm You can use it or flash to BU40N 1.03MK.
The BU40N and the BU50N are the same hardware. The different model names related to different distribution channels.
Thanks a lot for your reply. I used the "All You Need Firmware Pack (MartyMcNuts)\Slim External Drives\DE_LG_BU40N_1.03_MK.bin" and it works! But just curious to know whether there will be any difference between this "DE_LG_BU40N_1.03_MK.bin" and "mk-firmware-pack-20200720\MK\HL-DT-ST\BU50N\HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin"? Thanks again!
zittrig
#4 Post by zittrig » Mon Mar 16, 2026 12:58 pm
The BU40N / BU50N 1.00 is the original LG firmware and is nativly 4K friendly.
Advantage: You can use other tools like DVDFab also.
Disadvantage (in my opinion): The 1.03MK has less problems with difficult discs.
amurorx81
#5 Post by amurorx81 » Tue Mar 17, 2026 5:44 pm
zittrig wrote: Mon Mar 16, 2026 12:58 pm The BU40N / BU50N 1.00 is the original LG firmware and is nativly 4K friendly.
Thanks for your advice!
