BDR 212V UHD Guide
alfred60ski
Re: BDR 212V UHD Guide
Post by alfred60ski »
Hi Coopervid,
I'm ready to flash my drive, but I need the correct firmware file.
My drive is: PIONEER BD-RW BDR-212V 1.02 (Hardware SAT 8F00).
I have the BDRFlash tool ready, but the files I found are for S12JBK. Could you please send me the 1.01 bin file specifically for the BDR-212V (Vinpower) model?
I want to make sure I don't brick the drive by using the wrong version.
Thanks for your help!
alfred60ski wrote: Sun Mar 15, 2026 7:26 pm Hi Coopervid,
You have everything for flashing it. Go ahead.
alfred60ski
Hi Coopervid,
I need to correct my previous message. My drive is actually on the RS8F00 platform, not 8F00. Here are the exact details from MakeMKV:
Product: BDR-212V
Revision: 1.02
Firmware version: ID06
I tried using SDFtool Flasher with the S8F01431.102 file you mentioned, but it gave me an error: "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
It seems my 212V is the newer revision. Could you please provide the correct firmware for the RS8F platform?
Thank you!
alfred60ski wrote: Mon Mar 16, 2026 5:19 pm Hi Coopervid,
Product: BDR-212V
Revision: 1.02
Thank you!
Again. You have everything you need. Make sure the drive is closed, no disc in drive and you use the force flash check box. And SDFTool flasher is pointless. You need to use BDRFlash. And you have TO FOLLOW THE TUTORIAL.
ljabballe
Post by ljabballe »
Hello Coopervid.
I have the flasher for Pioneer BDR-212V.
I just picked up this (can I use same flasher?).
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: xxxxxxxxxx
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F01
Firmware version: 1.01/ID72
ljabballe wrote: Tue Mar 17, 2026 3:35 am Hello Coopervid.
Revision: 1.01
Yes.
hardened
Post by hardened »
Hi Coopervid, could you help me with my BDR-212EBK drive?:)
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: TKDL008178WL
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.01/ID56
hardened wrote: Wed Apr 01, 2026 9:40 am Hi Coopervid, could you help me with my BDR-212EBK drive?:)
Revision: 1.01
Sure. PM sent.
Mouse_Master
Post by Mouse_Master »
Hello Coopervid,
Can you help me with my Pioneer drive to enable UHD ripping? Thank you!
OS device name: E:
Product: BD-RW BDR-212V
Revision: 1.01
Serial number: {REDACTED}
Firmware date: 2021-07-20
Bus encryption flags: 13
Firmware version: 1.01/ID06
Mouse_Master wrote: Mon Apr 06, 2026 8:29 pm Hello Coopervid,
OS device name: E:
Revision: 1.01
PM sent.
Mouse_Master wrote: Mon Apr 06, 2026 8:29 pm Hello ,
OS device name: E:
Revision: 1.01
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Meeik
Post by Meeik »
Good evening @Coopervid,
I stumbled upon this post as I am finding via research that this drive can read 4K UHD discs, but placing one inside the device results in No disc.
I see in this post that you are providing assistance with this. If you are still, I would appreciate any that you are willing to send my way.
Revision: 1.02
Serial number: DGDL028316WL
Firmware date: 2022-05-31
Highest AACS version: 66
Hoping to enable LIbreDrive and UHD.
Thank you.
Meeik wrote: Sat Apr 25, 2026 1:01 am Good evening,
Revision: 1.02
Thank you.
Sure email me that drive info section see below for email
No need to post your info publicly just email me directly for pioneers
Wraith301
Post by Wraith301 »
Can you help me enable UHD on my Pioneer BDR-212V? Thank you.
OS device name: /dev/sr0
Revision: 1.02
Wraith301 wrote: Sat Apr 25, 2026 11:38 pm
Revision: 1.02
