Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
sammyd1108 wrote: Fri Mar 13, 2026 4:09 pm I’ll try it again when I get home I guess. I know I tried it right before posting my data dump and it still wasn’t opening.
I don’t want to sound rude but it wasn’t working for you earlier because you hadn’t followed the steps required to use the latest public keydb. Your disc has been in the keydb for almost 36 hours and the keydb entry is unambiguously correct.
Your issue will be at least one of:
1. You downloaded an ancient copy of the keydb from the wrong site instead of the one I linked in my instructions
2. You didn’t extract the keydb.cfg file from the downloaded zip file
3. You put the extracted keydb.cfg file in the wrong folder
4. (Linux/macOS only) You didn’t rename the keydb.cfg file to the case-sensitive KEYDB.cfg file required by certain filesystem configurations
There aren’t too many other ways to fuck up downloading, extracting and copying a file.
freshspaghettios
Post by freshspaghettios »
Disc type: UHD
Disc ID: 5187044E8B57FBAA1CB86BA66AD8E6E3A81D9470
Disc dump filename: MKB20_v82_We're_All_Gonna_Die_7B43
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ZQdAGP ... drive_link
Disc dump link: https://drive.google.com/file/d/1EE573A ... drive_link
I sent the dump to svq@makemkv.com as well. Let me know if I'm missing anything, hopefully the hash is right.
keydb_helper
JackBurton wrote: Fri Mar 13, 2026 4:20 pm The Narrow Margin
Disc type: Blu-ray
Disc dump filename: MKB_v82_THE_NARROW_MARGIN_8516.tgz
Stranger on the Third Floor
Disc type: Blu-ray
Disc dump filename: MKB_v82_STRANGER_ON_THE_THIRD_FLOOR_D84C.tgz
Thanks Jack, both of your discs have been added to the public keydb.
These two UHD discs were also just added:
MKB20_v82_Anaconda_(2025)_E6F4
MKB20_v82_K2_20A0
InstExtension
Post by InstExtension »
Heavy Metal 4k UHD
Disc type: UHD
Disc ID: 6a6db3629a38e2ae3cb8de52e0805353f2220771
Disc dump filename: MKB20_v76_Heavy_Metal_2989
MKB_RO.inf link: https://1drv.ms/u/c/850c3a15b7956143/IQ ... 8?e=DWgRdO
Disc dump link: https://1drv.ms/u/c/850c3a15b7956143/IQ ... g?e=AFPmd2
Yes, this Disc ID already exists in the current KeyDB, but it is not working for some reason. I tried with with two different UHD drives:
PIONEER BDR-S13JX
LG WH16NS60
The current KeyDB did work for some other titles I had problems with so I know its installed and working correctly.
jenrashe
Post by jenrashe »
Bambi The Reckoning (Bluray 4K)
Disc type: Bluray 4K
Disc dump filename: MKB20_v82_BDROM_BB32
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1_x8Oal ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1MC5wkl ... sp=sharing
Top
RandomSelf
Public KeyDB Disc Submissions - Seven (733A)
Post by RandomSelf »
Greetings all,
Disc type : UHD
Disc ID : 504382BF2637F8FE740CCF822B77FF0034DA3AD8
Disc dump filename : MKB20_v77_Se7en_733A
Drive : BD-RE ASUS BW-16D1HT
Drive firmware : 3.10
LibreDrive status : Enabled
Did you sync the public keydb within the last 15 minutes : Yes
Submission links are accessible in incognito/private browsing : Verified
MKB_RO.inf link : https://drop.chapril.org/download/efc84 ... Eq8h-T2iyg
Disc dump link : https://drop.chapril.org/download/82a3b ... jhI-Biag0w
All the best,
RandomSelf
Public KeyDB Disc Submissions - Emilia Pérez (0910)
Greetings all,
Disc type : UHD
Disc ID : 14B0E8E5CCAA28113B164BB521BF50B67CD2A6C7
Disc dump filename : MKB20_v77_BLU-RAY_UHD_0910
MKB_RO.inf link : https://drop.chapril.org/download/f4a9e ... TfNm2YVoBw
Disc dump link : https://drop.chapril.org/download/2df86 ... zKy3jbBqsg
All the best,
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v76_Heavy_Metal_2989
*MKB20_v77_BLU-RAY_UHD_0910 (Emilia Perez)
*MKB20_v82_BDROM_BB32 (Bambi: The Reckoning)
MKB20_v82_OPERATION_KABUL_6699
freshspaghettios wrote: Sat Mar 14, 2026 4:50 am Disc type: UHD
Hey freshspaghettios, thanks for the disc dump and welcome to the forum. I was pretty clear in the opening post that you shouldn't extract and upload the incomplete MKB_RO.inf file from within the disc dump:
keydb_helper wrote: Thu Jun 26, 2025 1:40 am Do not just extract the ~56 byte MKB_RO.inf file from a partial disc dump file and upload it separately. This is not helpful. Instead, copy the MKB_RO.inf file from the AACS folder on your disc and upload it separately. If your MKB_RO.inf file is not several megabytes in size, it is probably not useful for UHD discs.
You were lucky this time that the media key was already known for your disc, but future submissions will generally require the full MKB_RO.inf file.
freshspaghettios wrote: Sat Mar 14, 2026 4:50 am ...hopefully the hash is right.
You did calculate the disc ID/hash correctly, so your first was significantly better than the forum average.
I can't currently see the submission post for Heavy Metal, but I'll try to answer the question from memory. MakeMKV requires the volume unique key (VUK) in order to decrypt a disc via the public keydb. The 2989 variant of Heavy Metal (0x6A6DB3629A38E2AE3CB8DE52E0805353F2220771) had a record in the public keydb but it only contained the unit key. Now all four fields are known (media key, volume ID, volume unique key, and unit key(s)), MakeMKV will be able to process the disc after you grab the latest keydb.
warhorus
Post by warhorus »
Hello all,
The Mondo Macabro Halloween orders just started coming in, here's what needs adding:
Devil's Nightmare
Disc type : UHD
Disc ID : FA070EE356BE18370CE190FE04D6A7B924F4BAA0
Disc dump filename : MKB20_v77_DEVILS_NIGHTMARE_D0CA
MKB_RO.inf link : https://drive.google.com/file/d/19QdBwq ... drive_link
Disc dump link : https://drive.google.com/file/d/1Fsg8p5 ... drive_link
Inquisition (1976)
Disc type : UHD
Disc ID : 42F5243A3D913C8CE9E099E871FE11B4A2B041EF
Disc dump filename : MKB20_v77_INQUISITION_5C5A
MKB_RO.inf link : https://drive.google.com/file/d/1dvvjYT ... drive_link
Disc dump link : https://drive.google.com/file/d/1V9ytpJ ... drive_link
keydb_helper
warhorus wrote: Sat Mar 14, 2026 4:16 pm Hello all,
Devil's Nightmare
Disc type : UHD
Inquisition (1976)
Disc type : UHD
Hey warhorus, thanks for the new disc dumps. Both discs have been added to the public keydb.
fsutampaguy
Post by fsutampaguy »
(Deleted. I'm an idiot. It was a dirty disc. Have a good weekend. My apologies.)
Chelesty
Post by Chelesty »
Good sunday to y'all,
These are Now You See Me 2 and 3 of a trilogy boxset I just got. First movie ripped fine but the other 2 don't have a key in the db it seems.
Disc type: UHD
Disc ID: fe8b200601ec5e2315d64e9da4a6a60b1cf0de0f
Disc dump filename: MKB20_v82_INSAISISSABLES_2_3525.tgz
Drive: BW-16D1HT
Drive firmware: 3.10 Patched (microcode access re-enabled)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Included below
Disc dump link: https://drive.google.com/drive/folders/ ... sp=sharing
Disc type: UHD
Disc ID: 2ef7f345fcc261fd80575c83637724677cdefdcb
Disc dump filename: MKB20_v82_INSAISISSABLES_3_6709.tgz
Drive: BW-16D1HT
joh_0303
Post by joh_0303 »
I don't directly have a dump file because makeMKV get's stuck at a specific point.
So i used xreveal to create a metadata .jar file. I hope this works as well.
If you need anything else, please let me know. :)
Disc type: UHD
Disc ID: 11290E56B2BA50B8CF9EE49E467258304652CE46
Disc dump filename: 20230724_U77_M3GAN.jar
Drive: PIONEER BD-RW BDR-UD04
Drive firmware: 1.14
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): In the "dump" file
Disc dump link: https://drive.google.com/file/d/17zPKeN ... sp=sharing
keydb_helper
Chelesty wrote: Sun Mar 15, 2026 4:16 pm Good sunday to y'all,
Disc type: UHD
Disc type: UHD
Hey Chelesty, thanks for following the submission template. Both of your discs have been added to the public keydb.
In the future, I'd recommend trying out SamuriHL's KeyDB Tool for Windows. For your two latest discs it could've automatically derived the required keys and submitted them to the public keydb.
Bohuntin
Post by Bohuntin »
From the 6-movie Middle Earth box set, the 3 Hobbit disks are in the current keydb, but the LoTR ones are not.
Here are the details for the first disk (part 1 of fellowship, extended, UHD); will prep and upload the other 5 once I make sure this submission is correct.
Disc type: UHD
Disc ID: 0xCA34B47F1EB98119E5637B5C3A5F213648FBE0B7
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_EXT_PT_1_77C9.tgz
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1EXdixDsKy8KA3erAFXfA2mokBL_wme_H/view?usp=sharing
Disc dump link: https://drive.google.com/file/d/1QeKMub917yVKAAzEhbL7eV_s1fqWyzZ9/view?usp=sharing
