zootopia 2 bluray wrong language after ripping
Qcom512
Post by Qcom512 »
For some reason, after ripping zootopia 2 all the text is set to another language despite playing normally with the disc in english with vlc. Is this a bug?
Re: zootopia 2 bluray wrong language after ripping
If it displays in a different language, it is possible that the wrong one is set as default. If you open the MKV file with, say, handbrake or MKVtoolnix, what does it display as the default language?
(this assumes that you ripped both languages originally)
Qcom512
Post by Qcom512 »
checked with mkvtoolnix and it shows the video as english. Removing all subtitles and audio streams except the english 7.1 track also gives the same result.
Ezatoka
Post by Ezatoka »
Just today I ripped my (german) Zootopia 2 BluRay.
MakeMKV showed me the main movie in two playlists. in 00800 vor the English texts and (I think it was) 01714 for the German texts.
You have to select the correct playlist to rip.
PS: my Bluray ONLY has German and English... not a single other audio, or subtitle, none. only German and English...
Qcom512
Post by Qcom512 »
Ezatoka wrote: Sat Mar 14, 2026 5:48 pm Just today I ripped my (german) Zootopia 2 BluRay.
How do I rip the correct playlist? The guide isn't very helpful...thanks for showing what the problem is though!
Qcom512 wrote: Sat Mar 14, 2026 7:34 pm How do I rip the correct playlist? The guide isn't very helpful...thanks for showing what the problem is though!
Do you have Expert Mode enabled in MakeMKV? Changing names with Expert mode enabled
I'm pretty sure you'll need that turned on. Honestly I used MakeMKV for so long with it turned on that I've mostly forgotten what MakeMKV is like with it turned off. :D
In any case, for the north American release of a Disney movie like Zootopia there are probably two or three "copies" of the movie on the disc. In MakeMKV they'll show up as two or three separate titles with large file sizes and the length will be the full movie length. They might all have the same audio and subtitles, but in one all the writing in the movie will be in English. In another one all the writing will be in Spanish. In a third, it is probably French.
If you examine the segment map of each title you'll see some parts that are the same and some parts that are different between each title. The disc is making use of a feature of blu-rays called seamless branching. This is where a movie can be chopped up into multiple parts and seamlessly assembled on the fly into one coherent movie at playback time. This allows for multiple versions of a movie to be stored on a single disc without having to have multiple complete copies of the movie; only 1 copy of each part of each version of the movie needs to be stored. Usually a movie with multiple versions is mostly the same between the various versions of a movie. A playlist for each version is stored on the disc that defines which ordered set of segments belong to each version of the movie. The player plays the segments as defined in the playlist file seamlessly assembling them into the movie you see.
MakeMKV does this as well when .mkv files are made. Depending on which playlist you select, the segments are seamlessly assembled in order into one movie in a .mkv file. If you pick the wrong title/playlist in the MakeMKV interface you might end up with English audio but French visuals.
Qcom512
Post by Qcom512 »
Wow! I had no idea this was here. Thanks so much. I'll give this a shot.
Qcom512
Post by Qcom512 »
Well crud. I'm not understanding what to do.
how do I select a playlist? everything says english when I look at the chapters, but its still not right. I set the preferred language as english in settings too.
MakeMKV shows different playlists as different titles. Whichever titles are checkmarked are which 'playlists' you've selected. In your screen shot I can see the title selected is defined by 01716.mpls. The segment map has lots of items in it. If you highlighted the title two up from the one selected, it would probably be a different *.mpls file and the segment map would be partly the same and partly different.
If you check all the big, movie sized titles (I presume there are 3 of them) MakeMKV will produce 3 .mkv files, each assembled from the slightly different segments as defined by their *.mpls files. Undoubtedly one of them will be the version with English writing. All three of them probably have the English audio track.
As a side note, in the 'Properties' box, for the Name field, you could change it from "ZOOTOPIA 2 - BLU-RAY" to "Zootopia 2" or whatever you like. The resulting MKV file's name will start with whatever you set in the Name field and the name field in the .mkv file's metadata will be set to the same thing.
Qcom512
Post by Qcom512 »
ok wow. I didn't even see that one up there. I feel really dumb now. Thanks everyone. Atleast I learned something new!
StrangeBrew
Post by StrangeBrew »
All modern Disney movies have multiple versions. The playlist 800.mpls is the one for the U.S. and Canada. The others are usually for Japanese and German, and they have different languages on the in-movie words, but can still be played back with English. Just choose the 800 playlist every time when ripping Disney-owned discs and clean it up in Handbrake (forced subs, etc.). You can also expect this with Fox and Marvel films, most likely, too, since Disney now owns them. Don't get frustrated. This forum is a wealth of knowledge when you run into nasty things like this. Just wait until you have to rip a Lionsgate film with over 200 playlist versions. I have to rely on people who have the software to find and report the right playlist. Lionsgate has always been the BIGGEST PIA I've ever had to rip. I hope this helps for future rips.
Sayaka
Post by Sayaka »
I feel like participating in this thread necromancy to point out that for the Frozen II UHD Blu-ray (and some other Disney Blu-ray discs), 800 is English, 801 is French, 802 is Spanish and 803 is Japanese, in case this example could be of use to anyone.
EDIT : And it seems this could potentially be of use to somebody, since the names of the foreign dub voice actors may only show up in the correct playlist.
