AHCI
Spook
AHCI
I hate to beat a dead horse, and I've been able to get around the the need to use AHCI until recently. I've upgraded, and Apparently to run TRIM I will have to have my system configured for AHCI. MakeMKV has been very handy to cut down the number of steps required to convert a Bluray to MKV file, but like many, under AHCI, MakeMKV can't see the optical drives. My research on this trouble shows that the trouble seems to go way back, and I hope upon official release of this utility, these troubles can be ironed out. I'm only posting to explain, that among others MakeMKV won't be useful until this trouble is resolved.
Spook
Spook
- Contact:
Re: AHCI
This is NOT going to be corrected in the next version (1.4.9) but WILL be corrected in 1.4.10 . I wish I had better news, but that's it.
- Contact:
Re: AHCI
Everyone who encounters AHCI problem, please provide the following information: Are you using built-in windows drivers or intel matrix drivers and what driver version do you have? You can get this information in device manager, "driver" tab. Thanks.
adrian
Re: AHCI
Hi Mike!
I'm using the built-in drivers for Windows 7 Pro x64:
And this is the debug log from MakeMKV 1.49:
Hope this helps!
Standard AHCI 1.0 Serial ATA Controller
Driver Provider: Microsoft
Driver Date: 2006-06-21
Driver Version: 6.1.7600.16385Code: Select all
MakeMKV v1.4.9 beta win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\xxx/MakeMKV_log.txt
FAILURE: Code 3221225488 at QW,Bt.0%[OfJ[h:213130927
FAILURE: Code 3221225488 at /CW2w&;*mYHK*iE#:121263061
FAILURE: Code 0 at /CW2w&;*mYHK*iE#:121262762
FAILURE: Code 0 at ~2`#___>*HYme6[_^0D<8^F#ih:29393516
The program can't find any usable optical drives.-
pumkinut
Re: AHCI
Using Win7's built in drivers for Sony BD-ROM BDU-X10S:
Driver Date: 6/21/2006
Intel chipset drivers for G33/G31/P35/P31 Chipset
Microsoft AHCI 1.0 Serial ATA Controller:
Spook
Re: AHCI
I have downloaded and installed the latest : MakeMKV 1.4.10 for Windows, on my AHCI system, and it is working now. Well, I haven't finished the whole Bluray yet(its working on it), but it is definitely getting further than before.
Thanks Mike
Spook
Thanks Mike
Spook
