I have looked for hours and can not find the files to flash this Pioneer BDR-XD05S drive.
I can use the command line if needed.
Can anyone help? Not sure why this isn't more publicity available.
Instructions for BDR-XD05S
Re: Instructions for BDR-XD05S
The Pioneer flashing tools/firmware are not publicly available. Email your MakeMKV drive info & libredrive info sections to Billycar11.DangDandDoop wrote: Thu Mar 12, 2026 5:30 pm Hello,
Post your Makemkv info. No need to pay $40.DangDandDoop wrote: Thu Mar 12, 2026 5:30 pm Hello,
Or you can support people who put actual work and money into figuring out pioneer fw for both before and after 12/22 fw
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly for pioneers
DangDandDoop
I just spent a few hundred on drives and MakeMKV, any help is appreciated!Coopervid wrote: Thu Mar 12, 2026 10:08 pmPost your Makemkv info. No need to pay $40.DangDandDoop wrote: Thu Mar 12, 2026 5:30 pm Hello,
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 77
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
PM sent.DangDandDoop wrote: Fri Mar 20, 2026 8:59 pmI just spent a few hundred on drives and MakeMKV, any help is appreciated!Coopervid wrote: Thu Mar 12, 2026 10:08 pmPost your Makemkv info. No need to pay $40.DangDandDoop wrote: Thu Mar 12, 2026 5:30 pm Hello,
OS device name: E:
Revision: 3.01
Serial number:
AxionQc
Can you help me with mine too?Coopervid wrote: Fri Mar 20, 2026 10:10 pmPM sent.DangDandDoop wrote: Fri Mar 20, 2026 8:59 pmI just spent a few hundred on drives and MakeMKV, any help is appreciated!
OS device name: E:
Revision: 3.01
Serial number:
OS device name: /dev/sr0
Revision: 3.01
Serial number: QADL096548UC
No disc inserted-
PM sent.AxionQc wrote: Sun Apr 26, 2026 2:06 amCan you help me with mine too?Coopervid wrote: Fri Mar 20, 2026 10:10 pmPM sent.DangDandDoop wrote: Fri Mar 20, 2026 8:59 pm
OS device name: E:
Revision: 3.01
Serial number:
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: QADL096548UC Firmware date: 2014-12-26 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Sure email me that drive info section see below for emailAxionQc wrote: Sun Apr 26, 2026 2:06 am
No need to post your info publicly just email me directly for pioneers
f.zst
Hi guys,
is my drive flashable?
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-XD05
Revision: 3.10
Firmware-Datum: 2017-06-22
Highest AACS version: 82
Drive platform: RS8232
Firmware version: 3.10/ID34
OS-Gerätename: D:
Produzent: PIONEER
Revision: 3.10
PM sent.f.zst wrote: Thu May 07, 2026 6:29 pm Hi guys,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 3.10
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyf.zst wrote: Thu May 07, 2026 6:29 pm Hi guys,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 3.10
see below for email
f.zst
Thx guys! Worked like a charm.
I feel a little bit more relaxed for the future now that I have a second UHD capable drive as a backup to the drive I bought from asmcom
