LG BP55EB40 - flash issue
MFrost
Re: LG BP55EB40 - flash issue
Post by MFrost » Sat Feb 07, 2026 10:44 pm
thanks, you are very helpful :)
science-nerd
Post by science-nerd » Mon Feb 09, 2026 7:35 am
MartyMcNuts wrote: Sat Feb 07, 2026 10:06 pm
MFrost wrote: Sat Feb 07, 2026 4:47 pm Which svc code is recommended for flashing, and what is the best manufacturing date of the drive?
For flashing, a LG drive should meet all of the below:
Manufacture date 2016+
Drive platform MT1959
SVC: EB50, NB10, NB12, NB50, NB52, NS50, NS55, NS60 (not sure if there is an EB52 or not but if there is it shold be ok)
Basically, if a drive meets the first 2 but has SVC: EB40, NB40, NS40 forget about flashing it. It's not worth the risk, as you found out...
SVC EB52 works with flashing
Source: trust me bro (posted my drive details above and am happy to provide more info if anyone needs)
Horsecreek
Post by Horsecreek » Fri Feb 13, 2026 10:02 pm
I hope it's OK that I continue on this tread
I have a BP55EB40 drive too (It's a HL-DT-ST BD-RE BP55EB40 to be exact) with 'SVC Code EB52' on the box I've flashed it with the firmware for this drive. All OK. I can rip Blu-rays with no issues. But when I try to load a 4K disc it spins for a minute and then MakeMKV says "No disc inserted"
The drive supports BD-XL
Can I do anything to make it work?
OS device name: F:
Product: BD-RE BP55EB40
Revision: 1.03
Serial number:
Firmware date: 2120-05-07 09:24
Highest AACS version: 78
Firmware version: 1.03
Post by MartyMcNuts » Sat Feb 14, 2026 12:10 am
Horsecreek wrote: Fri Feb 13, 2026 10:02 pm I hope it's OK that I continue on this tread
OS device name: F:
Revision: 1.03
Serial number:
You need to cross-flash it now. Use the RECOVER method of SDFtool Flasher. See the section for BP50NB40 SVC: NB52 and the gif in the SDFtool Flasher thread.
MFrost
Post by MFrost » Sat Feb 14, 2026 10:30 pm
Can you provide the exact and correct step-by-step flashing procedure for an LG drive BP55EB40 SVC Code EB52? The information is somewhat scattered across the forum, and it’s hard to figure out what exactly needs to be done.
Thank you in advance.
Post by Billycar11 » Sun Feb 15, 2026 12:02 am
MFrost wrote: Sat Feb 14, 2026 10:30 pm Can you provide the exact and correct step-by-step flashing procedure for an LG drive BP55EB40 SVC Code EB52? The information is somewhat scattered across the forum, and it’s hard to figure out what exactly needs to be done.
See guide below or Marty guide both ways work
I would say if your not on windows my way would be easier other wise the same
science-nerd
Post by science-nerd » Sun Feb 15, 2026 12:17 am
If you are on Linux, see here viewtopic.php?f=3&t=40977
Otherwise use the GUI tool on windows, it is easier to use than commands. But the individual flashing steps by themselves are identical
Horsecreek
Post by Horsecreek » Sun Feb 15, 2026 9:19 am
MartyMcNuts wrote: Sat Feb 14, 2026 12:10 am
Read - Think - Understand - Think - Do it right.
That's a tough process but I succeded. :D :lol:
Now I'm working my way through the 4Ks that my Asus drive couldn't read
viewtopic.php?f=16&t=22896&hilit=SDFtool+Flasher
My workthrough
- first I flashed my drive with the BP50NB40 (NB50) 1.03-MK firmware. I'm not sure if that was necessary at all. Because it didn't effectively changed anything
- Then I flashed with the 'DE_LG_BU40N_1.00.bin' from the zip-file from the link above. Now It works perfect.
Bardehose
Post by Bardehose » Thu Mar 12, 2026 4:46 pm
I have the exact same drive as you. I also flashed both firmwares one after the other. Unfortunately, I still have the same problem with UHD movies as you did at the beginning. Does anyone have any idea what I'm doing wrong? Here is the information from Make MKV:
OS device name: E:
Revision: 1.03
Serial number:
Post by MartyMcNuts » Thu Mar 12, 2026 10:03 pm
Bardehose wrote: Thu Mar 12, 2026 4:46 pm Hi,
OS device name: E:
Revision: 1.03
Serial number:
You have only done the first part. You now need to do the cross-flash by means of the RECOVER step. In the SDFtool Flasher thread, read the section on BP50NB40 SVC NB52 and follow the steps / gif from the RECOVER part.
Bardehose
Post by Bardehose » Sun Mar 15, 2026 9:24 pm
Thanks. After reading it three times, I finally got it :lol:. It worked right away.
johannu
Post by johannu » Fri Mar 20, 2026 1:14 pm
I have a question crossflashing LG BP55EB40 SVC EB40 for UHD compatibility.
If I understand right, this post says no: viewtopic.php?p=194641#p194641
You have an SVC: EB40 which should never have been flashed. It is not UHD compatible. Please stop flashing it. It should at least work as it did before. There is very little difference (if any) between the BP55EB40 and the BP50NB40.
and this post says yes: viewtopic.php?p=181611&sid=fcdef59e5173 ... 8f#p181611
Go to the SDFtool Flasher thread and read the section on SVC NB52, even though your's is SVC EB40
So does crossflashing work or not?
Post by Coopervid » Fri Mar 20, 2026 1:23 pm
Check the date of the firmware. Only drives with firmware after late 2015 can be flashed for UHD.
johannu
Post by johannu » Fri Mar 20, 2026 4:19 pm
Does that mean, if the BP55EB40 has SVC EB40 and has firmware after late 2015, it can be crossflashed for UHD compatiblity, otherwise not. Right?
Post by Coopervid » Fri Mar 20, 2026 5:01 pm
johannu wrote: Fri Mar 20, 2026 4:19 pm
Post your Makemkv info and hope for Marty's answer. He is the authority.
