Rips fine, but doesn't play
lolainslacks
Post by lolainslacks » Tue Mar 27, 2012 5:38 pm
I've been trying to rip many Blu-rays, but they just aren't recognized by players such as KMPlayer. This started happening out of nowhere.
Please help?
I use a bought license.
lolainslacks
Re: Rips fine, but doesn't play
Post by lolainslacks » Wed Mar 28, 2012 6:25 am
Ok, I got other Blu-rays to rip and play fine. I'm having troubles with Don't Say A Word and Just Married.
Here's the log from Don't Say A Word:
Debug log started at Tue Mar 27 23:17:19 2012 , written by MakeMKV v1.7.2 win(x86-release)
001005:0000 MakeMKV v1.7.2 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Roberta/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=LhMxMDqIYADQoJBlZAUTqEWG6yRlbTNI6ttpPoqMgvVnU+Cv+SXWIsPV+0Yk/jaSaoEeV8YzF5JT1NUBg0pIC0mJKY4ON9rLkbtifubXo/RdIpR8lZbkQj2aB5KqPEr1GHzxqVLTF22kVQr73o8O1BHZ3MqRTu4z7w==
003317:0000 Loaded 21 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00003.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=A98E7630AE3898B35EAF1684B12F1CCA40C6F577
003307:0000 File 00323.m2ts was added as title #0
003309:0000 Title 00323.m2ts is equal to title 00323.m2ts and was skipped
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00375.mpls was added as title #1
003025:0000 Title #00020.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00850.mpls is equal to title 00375.mpls and was skipped
003307:0000 File 00329.mpls was added as title #2
003307:0000 File 00333.mpls was added as title #3
003307:0000 File 00351.mpls was added as title #4
003307:0000 File 00312.mpls was added as title #5
003307:0000 File 00315.mpls was added as title #6
003307:0000 File 00318.mpls was added as title #7
003307:0000 File 00321.mpls was added as title #8
003309:0000 Title 00324.mpls is equal to title 00323.m2ts and was skipped
003309:0000 Title 00802.mpls is equal to title 00375.mpls and was skipped
003309:0000 Title 00852.mpls is equal to title 00375.mpls and was skipped
003309:0000 Title 00801.mpls is equal to title 00375.mpls and was skipped
003307:0000 File 00352.mpls was added as title #9
003307:0000 File 00353.mpls was added as title #10
003025:0000 Title #00354.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00355.mpls was added as title #11
003309:0000 Title 00356.mpls is equal to title 00323.m2ts and was skipped
003309:0000 Title 00800.mpls is equal to title 00375.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00375.mpls and was skipped
003025:0000 Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00345.m2ts was added as title #12
003307:0000 File 00325.m2ts was added as title #13
003307:0000 File 00346.m2ts was added as title #14
003307:0000 File 00328.m2ts was added as title #15
003025:0000 Title #00334.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00335.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00336.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00339.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00340.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00341.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00344.m2ts was added as title #16
003025:0000 Title #00347.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00310.m2ts was added as title #17
003307:0000 File 00313.m2ts was added as title #18
003025:0000 Title #00316.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00317.m2ts was added as title #19
003307:0000 File 00319.m2ts was added as title #20
003307:0000 File 00322.m2ts was added as title #21
003307:0000 File 00359.m2ts was added as title #22
003025:0000 Title #00020.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory H:/BLU-RAYS & DVDS/BRITTANY
004001:0000 Forced subtitles track #15 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #23 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #27 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #29 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #31 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #33 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #35 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #39 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #41 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #43 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #45 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #47 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #51 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #55 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #57 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #59 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #61 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #67 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #69 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #71 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #73 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Wed Mar 28 06:21:53 2012
Please help, I'm desperate!
lolainslacks
Post by lolainslacks » Wed Mar 28, 2012 11:44 am
And this is the log from Just Married:
Debug log started at Wed Mar 28 06:56:45 2012 , written by MakeMKV v1.7.3 win(x86-release)
001005:0000 MakeMKV v1.7.3 win(x86-release) started
DCE=AKB/TIc8LgZo4GoY8xArCmiLW93wAlhzRg85oek3GzyNo9fkjaFVyQx3xwEUrGTB72fphHvzYro8gzCLcOhu1fo9HOtLXzHc4k/Pp4D9fOaksqygio6juQeF/89x39VIlTL67UTvQaB0QlvhWGDwDwJOzp/K0myGTg==
DISCID=C6523D54BB4F5CD1E65F6F7CA01509C99743F0CB
003307:0000 File 00600.mpls was added as title #0
003025:0000 Title #00020.mpls has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00300.mpls was added as title #1
003307:0000 File 00320.mpls was added as title #2
003309:0000 Title 00800.mpls is equal to title 00600.mpls and was skipped
003309:0000 Title 00801.mpls is equal to title 00600.mpls and was skipped
003309:0000 Title 00850.mpls is equal to title 00600.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00600.mpls and was skipped
003307:0000 File 00887.m2ts was added as title #3
003307:0000 File 00888.m2ts was added as title #4
003307:0000 File 00889.m2ts was added as title #5
003025:0000 Title #00020.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
004001:0000 Forced subtitles track #10 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #18 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #20 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #22 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #24 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #28 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #32 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #36 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #38 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #40 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #42 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #44 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #46 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #48 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #50 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #52 turned out to be empty and was removed from output file
Application exited at Wed Mar 28 11:42:38 2012
lolainslacks
Post by lolainslacks » Sat Mar 31, 2012 9:47 am
Can somebody please help me?!?!
Post by mike admin » Sat Mar 31, 2012 11:56 am
Your logs show no errors so it looks you have a general problems with MKV playback. Can you play these files with VLC? Can you play any MKV files?
lolainslacks
Post by lolainslacks » Sat Mar 31, 2012 4:05 pm
mike admin wrote:Your logs show no errors so it looks you have a general problems with MKV playback. Can you play these files with VLC? Can you play any MKV files?
No, they aren't recognized. I can play other mkv files just fine. Like I said, I'm just having problems with these two.
Post by mike admin » Sun Apr 01, 2012 12:01 pm
Please post mediainfo output for produced mkv files. Also check if video codec is VC-1; if it is then search this forum for the gory details.
lolainslacks
Post by lolainslacks » Sun Apr 01, 2012 6:54 pm
mike admin wrote:Please post mediainfo output for produced mkv files. Also check if video codec is VC-1; if it is then search this forum for the gory details.
How do I do that?
lolainslacks
Post by lolainslacks » Mon Apr 02, 2012 7:13 am
Do I have to download that and do what? And how do I check if the video codec is VC-1? Please explain better as I'm pretty ignorant when it comes to these things, I'm sorry. :\
lolainslacks
Post by lolainslacks » Sat Apr 14, 2012 2:10 am
Please help me!!!
lolainslacks
Post by lolainslacks » Sun Apr 15, 2012 9:24 am
rexoatis wrote:You can play any MKV files if they are with VLC.
Yes, but I can't play those.
lolainslacks
Post by lolainslacks » Sun Apr 15, 2012 9:51 am
Please help me out with this!
lolainslacks
Post by lolainslacks » Sun Apr 15, 2012 2:32 pm
I can't seem to install VC-1. I'm on Windows 7.
Please help!
lolainslacks
Post by lolainslacks » Sun Apr 15, 2012 2:38 pm
Nevermind. Got the Just Married mkv to play on KMPlayer, but not on Boilsoft Video Splitter, which I need to split the mkv files. It says it's not recognizable.
Help?
