Buffalo MediaStation BRXL-16U3 USB 3.0, Help Needed
captcavy
Hi Everyone, I purchased the Buffalo MediaStation BRXL-16U3 USB 3.0 External Blu-ray Burner, I opened up the External enclosure to get the drive info and it is the LG Model: BH16NS58 (AXJA3HB) ROM VER: 1.03, DRIVE REV: A0, MANUFACTURED: OCTOBER 2024, I Would like to know what is the correct loader and the correct 1.02 firmware to unlock the drive for ripping uhd on a Windows 10 PC and Windows 10 Laptop, also can I do this flash with USB 3.0 Or will I need to do this through the SATA, also is the factory external case suitable or should I put it in a better external enclosure, and if so what is the best enclosure to put it in. Thank You everyone,
Re: Buffalo MediaStation BRXL-16U3 USB 3.0, Help Needed
Flash to WH16NS60 1.02-MK.captcavy wrote: Thu Mar 12, 2026 11:16 am Hi Everyone, I purchased the Buffalo MediaStation BRXL-16U3 USB 3.0 External Blu-ray Burner, I opened up the External enclosure to get the drive info and it is the LG Model: BH16NS58 (AXJA3HB) ROM VER: 1.03, DRIVE REV: A0, MANUFACTURED: OCTOBER 2024, I Would like to know what is the correct loader and the correct 1.02 firmware to unlock the drive for ripping uhd on a Windows 10 PC and Windows 10 Laptop, also can I do this flash with USB 3.0 Or will I need to do this through the SATA, also is the factory external case suitable or should I put it in a better external enclosure, and if so what is the best enclosure to put it in. Thank You everyone,
No need to mess with anything. Just connect the enclosure USB and flash it.
renako
I purchased the Buffalo MediaStation BRXL-16U3 USB 3.0 External Blu-ray Drive, and drive info are follows:
OS device name: P:
Current profile: DVD-ROM
Product: BD-RE BH16NS58
Revision: 1.03
Serial number: KLQOBxxxxxx
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
Highest AACS version: 82
To make it a UHD readable, should I flash it using
1. SDFtool Flasher v1.3.6
2. HL-DT-ST-BD-RE_BH16NS60-1.02-NM00600-212005081014.bin (found in a folder MK/HL-DT-ST/BH16NS60) or a different FW?
I have MakeMKV 1.18.3 installed. Should I downgrade it to 1.17.7 it before flashing?
OS device name: P:
Revision: 1.03
on windows thats not needed you can stay on the latest versionrenako wrote: Sun Apr 05, 2026 12:17 am I purchased the Buffalo MediaStation BRXL-16U3 USB 3.0 External Blu-ray Drive, and drive info are follows:
OS device name: P:
Revision: 1.03
renako
Thank you for clarification regarding MakeMKV.
To confirm, for a Model BH16NS58 Rev. 1.03; it is recommended to use BH16NS60-1.02
(P.S. I saw a folder for BH16NS58 with BH16NS58-1.01 in it.)
WH16NS60 1.02-MK is recommended.renako wrote: Sun Apr 05, 2026 1:36 am Thank you for clarification regarding MakeMKV.
renako
Thank you, Billycar11.
Flashing went flawlessly on Windows 11 PC, and UHD reading works.
The only thing I hope is for these Hitachi-LG drives inside Buffalo case to last.
