epicchancellor
Re: SDFtool Flasher
Post by epicchancellor » Wed Mar 11, 2026 11:21 am
MartyMcNuts wrote: Wed Mar 11, 2026 3:52 am
epicchancellor wrote: Tue Mar 10, 2026 1:37 am Hi all,
After doing some investigation on Reddit in regards to flashing a 4K firmware onto my ASUS BW-16D1-XU drive, a user said I could use a firmware for what seems to be an LG drive (DE_LG_WH16NS60_1.02_MK) and it worked for that user. Trying to flash it onto my drive and it spits out an error, screenshots attached. I'm super new to this so any advice would be greatly appreciated!
Take the disc out of the drive!
Thank you for that! I didn’t think there was a disk in there but the flash did work! I tried putting in Ballerina and it still didn’t recognize the media. I didn’t have the chance to try another disk before I had to head out so is it a chance the media is just too new or something?
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Mar 11, 2026 10:48 pm
epicchancellor wrote: Wed Mar 11, 2026 11:21 am
Balleriina has been out for months so doubt it. Have you made sure MakeMKV has internet access? It is required so that MakeMKV's internal Hashed Keys database can be downloaed and updated as required.
You can also copy and paste the MakeMKV drive info & libredrive info sections so we can ensure the flash worked.
Copy and paste the log window text when you get an error or what not so that we can help further.
epicchancellor
Re: SDFtool Flasher
Post by epicchancellor » Wed Mar 11, 2026 11:37 pm
I think I see my issue; LibreDrive status is marked "possible, not yet enabled", not "enabled".
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLGP37D4330
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 68
I flashed it with the previously mentioned firmware, at least I thought I did? Maybe it somehow got screwed up?
epicchancellor
Re: SDFtool Flasher
Post by epicchancellor » Wed Mar 11, 2026 11:42 pm
Please disregard my prior comment; I reflashed the firmware, and it now reads "enabled" under the status. Guess I screwed something up! As a sanity check, I threw in my 4K copy of Ballerina and it worked. Thank you guys for the excellent help and patience!
neo14
Re: SDFtool Flasher
Post by neo14 » Sun Mar 15, 2026 12:25 pm
I have an Asus drive (WH16NS60) flashed with 1.02 version (LG)...I am having problems to rip some discs (sean connery 6 films and tried with 2 different copies)...I saw there is a 1.03 version...should it flash it with the most new one? Where I can find the last version? In the firts page I download the zip with all bin but I only see 1.02
Re: SDFtool Flasher
Post by Billycar11 » Sun Mar 15, 2026 12:42 pm
neo14 wrote: Sun Mar 15, 2026 12:25 pm Image
most likely not a fw issue
we need to know the error to help could be a key download issue or dirty disc's or laser or a failing drive
neo14
Re: SDFtool Flasher
Post by neo14 » Sun Mar 15, 2026 2:01 pm
Billycar11 wrote: Sun Mar 15, 2026 12:42 pm
I opened a thread:
viewtopic.php?f=12&t=41310
This is the second pack I have, so I discard problems with discs. Some of them I was able to rip, like From Russia with Love, Goldfinger, Thunderball...the rest impossible. Now I made a backup with makemkv of Diamonds are Forever and I receive this error:
a file did not exceed the hash
sgibbers17
Re: SDFtool Flasher
Post by sgibbers17 » Wed Mar 18, 2026 10:39 pm
I just downloaded the tool but does not show up correctly on my windows 11 machine. It appears that the windows is too small and I can not see the check marks and the text is cutoff. Windows will not let me make the window bigger.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Mar 18, 2026 10:48 pm
sgibbers17 wrote: Wed Mar 18, 2026 10:39 pm I just downloaded the tool but does not show up correctly on my windows 11 machine. It appears that the windows is too small and I can not see the check marks and the text is cutoff. Windows will not let me make the window bigger.
From the first post.
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
sgibbers17
Re: SDFtool Flasher
Post by sgibbers17 » Wed Mar 18, 2026 10:56 pm
MartyMcNuts wrote: Wed Mar 18, 2026 10:48 pm
that didn't work the app will not even show up.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Mar 18, 2026 10:58 pm
sgibbers17 wrote: Wed Mar 18, 2026 10:56 pm
What?!?
1. right click the exe
2. select properties
3. In the compatibility tab, click "Change high DPI settings"
4. under "High DPI scaling override" tick the box and select "System (Enhanced)"
5. click apply and close this window
6. Now run the exe.
sgibbers17
Re: SDFtool Flasher
Post by sgibbers17 » Wed Mar 18, 2026 11:33 pm
MartyMcNuts wrote: Wed Mar 18, 2026 10:58 pm
What?!?
6. Now run the exe.
This is a screenshot of before settings are changed.
Screenshot of my settings
what it looks like with the new settings.
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Mar 19, 2026 3:49 am
sgibbers17 wrote: Wed Mar 18, 2026 11:33 pm
What?!?
6. Now run the exe.
Wow, never seen that happen before! Just download the old original from the first post and use that. It should look correct.
h3jdoktqLGP4PygBp
Re: SDFtool Flasher
Post by h3jdoktqLGP4PygBp » Fri Mar 20, 2026 7:21 pm
I am unable to use SDFtool Flasher on VMware Fusion (Windows 11 Home Arm) via my ARM-based M2 Mac. Here's the drive info from makemkv running on my mac:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK05Q91B1943
Firmware date: 2121-07-08 16:03
Highest AACS version: 82
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Here's the same info as reported by makemkv running in my VMware Windows VM:
OS device name: E:
Manufacturer: NECVMWar
Product: VMware SATA CD00
Revision: 1.00
When I load the SDFtool (v1.3.6) and select the drive I get the following error:
System.FormatException: Input string was not in a correct format.
   at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
   at System.Int32.Parse(String s)
   at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.6.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
System.Runtime.CompilerServices.Unsafe
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
I can hit continue on the error but I can't dump the existing firmware or write new firmware to the drive.
Re: SDFtool Flasher
Post by Coopervid » Fri Mar 20, 2026 7:33 pm
You can't dump the firmware on any platform. Only the calibration info.
You need to modify the options in VMWare to pass the drive through. Not only via the emulation. Can't remember how but just google it.
