Pioneer adjacent?
Jman5150
Pioneer adjacent?
Post by Jman5150 » Tue Mar 10, 2026 3:46 am
Anyone know of a souce for any pioneer flashable drives regardless of price or adjacent (like import knockoffs that are known to work if such a thing exist?
. I did get a LG BP60NB10 and a buffalo for backup. I do have one from billy but considering the supply issue may be permant you know how it is.... Obviously this is a hail marry pass
Any truth that the buffalo drives scratch disks?
Anyway Thx! I know everyone is scrambling to try to get whats left before its all $1000+ or soemthung nutty. Hope are are well.
Re: Pioneer adjacent?
Post by Coopervid » Tue Mar 10, 2026 9:08 am
Jman5150 wrote: Tue Mar 10, 2026 3:46 am Anyone know of a souce for any pioneer flashable drives regardless of price or adjacent (like import knockoffs that are known to work if such a thing exist?
Check this:
viewtopic.php?f=20&t=41222
keydb_helper
Post by keydb_helper » Tue Mar 10, 2026 1:59 pm
Jman5150 wrote: Tue Mar 10, 2026 3:46 am Any truth that the buffalo drives scratch disks?
Portable, USB-powered drives from any manufacturer seem to have an increased potential for scratching discs. I've personally had discs scratched by two Pioneer portable drives (BDR-UD04 and BDR-XS07U). I've known other folks to have negative experiences with LG BU40N/BP50NB40 and Pioneer XD07/XD08 drives.
If you keep your drives on a stable, flat, anti-slip surface and avoid ripping discs with stickers or visible warping you should be fine with any LibreDrive compatible drive.
Public KeyDB Disc Submissions
Jman5150
Post by Jman5150 » Wed Mar 11, 2026 6:11 am
Thanka cooper! I emailed
Question? Are these pioneers these that rip hard to rip disks? I could use backup either way just curious. Thanks!
Jman5150
Post by Jman5150 » Wed Mar 11, 2026 6:13 am
Good to know!
keydb_helper wrote: Tue Mar 10, 2026 1:59 pm
Post by Coopervid » Wed Mar 11, 2026 11:12 am
Jman5150 wrote: Wed Mar 11, 2026 6:11 am Thanka cooper! I emailed
Yes. The only thing that you need to know that rip speed for all Pioneers and UHD discs is limited to 4x speed. But better slower and successful than a failed rip with LG type drives.
