OEM HL-DT-ST:BD-RE BU40N CB05 not accepting MK firmware
sjwheel
Post by sjwheel »
I’m unable to flash a BU40N OEM internal slim drive with the libredrive firmware. Flashing reports successful, but after power cycling, the drive still shows “Possible, not yet enabled”, and the CB05 version.
I’ve directly connected it to my motherboard with a SATA cable.
Using Makemkv 1.17.6 from:
https://www.makemkv.com/download/old/ma ... 7.6.tar.gz
sdf from here:
https://makemkv.com/sdf.bin
root@k3:~/flash# makemkvcon f -d /dev/sr0 --info
SDF.bin version: 0x009C
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N CB05:H000600:-
root@k3:~/flash# makemkvcon f -d /dev/sr0 -f ./sdf.bin rawflash enc,slim -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Using an USB slim drive handshake
Current Drive ID: HL-DT-ST_BD-RE_BU40N_CB05_211711291351_N706HS001855
yes
100% Operation finished
Done successfully
Does anyone know a sequence of images to flash that will allow the drive to accept a libredrive firmware?
Thanks,
Steven
zittrig
Re: OEM HL-DT-ST:BD-RE BU40N CB05 not accepting MK firmware
Post by zittrig »
Please post your MakeMKV drive info.
No enc man
sjwheel
Post by sjwheel »
Billycar11 wrote: Tue Mar 10, 2026 11:16 pm No enc man
Thank you! Dropping the `enc` worked.
