Feature Request - Clear all check boxes at once
cuddlebunny
Post by cuddlebunny »
I have recently purchased John Wick box set and am having to uncheck 100+ boxes for multiple copies of the files. It would be nice if there were an option to uncheck all the boxes all at once, and then just go back and check the one or two i actually need.
regards,
CB
Re: Feature Request - Clear all check boxes at once
Have you tried <right-click> and select "unselect ALL" yet? It's relatively new... only been there for a dozen years or so... :)
cuddlebunny
I just figured that out. I started using the software a month ago.
99% of interfaces have a check box at the top that controls all check boxes below. I didn't think to try a right click.
It might be nice to add that to make it easy for dummies, but since I can clear them all with a right click, this dummy is all set!
Cb
dynasty8122
Post by dynasty8122 »
Hah--I was *just* going to post this exact request, and for the same disc. I was super bummed when shift-unclick did not work. Glad to know this "one simple trick".
