Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
nicholfd
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Post by nicholfd »
stephen273 wrote: Fri Feb 20, 2026 3:48 pm Would this work for ripping with WH16NS60
https://www.ebay.com/itm/257253275878?m ... ame=111011
This is the case billycar11 is recommending: OWC Mercury Pro - $59.99.
OWC also sells through Amazon: OWC Mercury Pro.
Thanks,
Frank
omeglidan
Post by omeglidan »
I'm looking to purchase an internal Pioneer but I can't make out the difference between the available models. What is the difference between Pioneer 212, BDR-213, 2213, BDR-S13UBK, BDR-S13U-X. My understanding is that they all read at the same speed (BD100 at 90 minutes). Is my understanding wrong, are some faster, are some more reliable?
Can someone please enlighten me as to why I would choose any of the four. Thank you.
omeglidan wrote: Sun Feb 22, 2026 5:02 am I'm looking to purchase an internal Pioneer but I can't make out the difference between the available models. What is the difference between Pioneer 212, BDR-213, 2213, BDR-S13UBK, BDR-S13U-X. My understanding is that they all read at the same speed (BD100 at 90 minutes). Is my understanding wrong, are some faster, are some more reliable?
not sure why this was asked in 3 places email here and reddit but
i found the xd08 to be the most reliable and durable actually had all of those other pioneers die in the mail even with 2 inches of foam and 2 inches of bubble wrap and being double boxed.
the are pretty much functionally the same the 212 and 213 and s13 just use slightly better components and more sound dampening
but sadly all drives are gone for now i will get more pioneers but very limited amounts only way to get them is to follow here and get my paypal links in an email so order asap when they go up
Purpull
Post by Purpull »
Following thread for any restocks! :D
OldPlextor
Post by OldPlextor »
nicholfd wrote: Sun Feb 22, 2026 4:27 am
Thanks,
Frank
Hrmmmm so I have just ordered the Vantec NexStar DX2 enclosure to house my Pioneer BDR-S09J and I certainly don’t want the enclosure to fry my drive…
The problem is, the Pioneer S09 has depth of 181mm, which means it won’t fit inside the OWC Mercury Pro Enclosure.
Is there another recommended enclosure? I liked the looks of the Vantec enclosure - what a shame it has some power issues!
OldPlextor wrote: Tue Mar 10, 2026 2:05 am
Thanks,
Frank
nah you just kinda have to deal with it slot the tabs or bend them
and someone made a 3d printable file to extend the front so it appears to not stick out
StrangeVideo
Post by StrangeVideo »
Or you can go simple: Shove the drive as far back in the OWC case as you can, and then put a piece of 3M VHB double-sided tape at the back and stick the drive to the bottom of the case. Securely held, but minimizes the protuberance.
Don't use too big a piece of VHB or you'll never get the drive out again.
cae-len
Post by cae-len »
following and hoping for a restock :|
-Cal-
Paradox
Post by Paradox »
Following. Hoping for more XD08s to come in, no matter the color.
stephen273
Post by stephen273 »
Thanks,
Frank
I asked in this thread if the Vantec would work and I never got an answer. Only people telling me answers to questions I never asked. So I went ahead and bought one and it works great!
stephen273 wrote: Fri Mar 13, 2026 4:57 am
Thanks,
Frank
I responded to you the other 2 times saying I recommend the owc
viewtopic.php?f=16&t=19634&p=195966#p195974
There is an one of them^
I guess good luck hope it don't kill your drive just kinda strange you ask for advice I tell you what I recommend then you complain you didn't ask.
Also why post to my selling post?
We have done no business
stephen273
Billycar11 wrote: Fri Mar 13, 2026 1:29 pm
My apologies. I must not have been clear. I just wanted to know if the Vantec would work. It is nice to know why you recommend the OWC.
I have a flashed 212XLT from Asmcom that came in a Vantec. No issues.
Post by SamuriHL »
I have Vantec cases on all my drives and I concur with Billy's advice to skip them. I just had one die. Unsure if it took the drive with it (it's an LG thankfully) but while I've had no other issues with my other cases, why chance it? Get OWC and sleep better at night. It's not like you can easily replace drives these days. I plan on replacing all my Vantec cases one at a time with OWC.
