AACS v31
Locked
AACS v31
Post by mike admin » Sat Mar 31, 2012 12:34 pm
The latest version of MakeMKV 1.7.3 can't handle very recent discs that use AACS v31. Until the next version is released, you need to do few additional steps in order to open these discs with any version of MakeMKV.
1. Confirm that your disc uses AACS v31 - it should be shown in "Protection" string on main screen.
2. Download attached text file and place it into "MakeMKV data directory". You can view or change it in MakeMKV preferences, on "General" tab.
3. Try opening the disc again. It will take about 10 minutes to open the disc, but the disc should open.
If disc still doesn't open then it means that disc key is not present in attached text file. Please do the following:
1. Make an encrypted full disc backup with MakeMKV
2. From this backup copy two files - MKB_RO.inf and discatt.dat and compress these files with any archiver.
3. Send produced archive file with disc name to support@makemkv.com
aacsv31-keys.txt
(507 Bytes) Downloaded 3051 times
Mnemos
Re: AACS v31
Post by Mnemos » Sun Apr 01, 2012 7:38 am
Okay then. So, if the MakeMKV data directory were "/home/username/.MakeMKV", then aacsv31-keys.txt is supposed to be put in there such that it's "/home/username/.MakeMKV/aacsv31-keys.txt", correct? And then without doing anything else whatsoever, makemkv should be able to decrypt any of the discs listed in that file, correct? Or have I misunderstood something?
I followed those steps exactly, and makemkv hasn't been able to decrypt any of the discs listed in the file (and I tried all 6). In all cases, it says that "The volume key is unknown for this disc - video can't be decrypted."
So, either I'm doing something wrong, or there's something wrong with makemkv and/or with the file that you've provided.
Re: AACS v31
Post by mike admin » Sun Apr 01, 2012 12:23 pm
If you start MakeMKV, insert one of these discs, is there a line named "bus encryption flags" on the right pane, under disc information?
Mnemos
Re: AACS v31
Post by Mnemos » Sun Apr 01, 2012 9:57 pm
No. The only fields that show up under disc information are
Data capacity
Disc type
Number of layers
Channel bit length
It's the same for all of the discs in the file.
Re: AACS v31
Post by mike admin » Wed Apr 04, 2012 12:05 pm
Sigh, this is a confirmed bug in 1.7.x series and probably few versions before. There is a workaround however - the text file must be present in both MakeMKV data directory AND current working directory. On Linux the easiest way is to copy the file into home directory, launch terminal, cd ~ , and then start makemkv from command line.
Mnemos
Re: AACS v31
Post by Mnemos » Thu Apr 05, 2012 6:55 am
Okay. I can confirm that if I symlink aacsv31-keys.txt into the current working directory before starting makemkv from the command line, makemkv is able to open all 6 of the discs in the file.
Re: AACS v31
Post by mike admin » Mon Apr 16, 2012 9:30 am
AACS v31 is supported by 1.7.4 without the need of any text files.
Locked
