How to Purchase MakeMKV
tatertot772
Post by tatertot772 »
I went to the website and click everything button i could find to try and purchase it but there is only a Beta Version which is free and awesome but I want to buy the Non-Beta version to help that continue to support the product. Is there not a full paid version?
Re: How to Purchase MakeMKV
tatertot772 wrote: Mon Mar 09, 2026 10:19 pm I went to the website and click everything button i could find to try and purchase it but there is only a Beta Version which is free and awesome but I want to buy the Non-Beta version to help that continue to support the product. Is there not a full paid version?
https://www.makemkv.com/buy/
The difference between "beta" and "full" versions is whether or not you have a key that doesn't expire every 60 days. The link show above takes you to purchasing a key, that will make whatever version you have installed work without the clock complaining... :)
The link itself is in the program; when you click Help->Purchase within MakeMKV, it will open that page in your browser.
GadgetAngel
Post by GadgetAngel »
I can't even buy a permanent key. The website isn't accessible either via https://www.makemkv.com/buy/ or through the beta key entry field. Does anyone else have trouble buying a permanent key?
zminator15
Post by zminator15 »
Yes, I am too. I think it had been down since July. :/ Right as I started getting into backing up my media collection.
