BD-RW BDR-208M
nosfrenatu
BD-RW BDR-208M
Post by nosfrenatu »
using the search I got opposing information about my drive, but this might be due to the time the comments were made. In 2023 the drive seemed not possible to flash, however a post from early 2026 sounded promising.
Manufacturer: PIONEER
Product: BD-RW BDR-208M
Revision: 1.10
Serial number: xxxxx
Firmware date: 2012-08-22
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID60
When opening the SDFtool Flasher out of curiosity it gives a complaint about the drive platform.
Can anyone give me a hint, will it be possible to read UHD content?
Thanks for your help.
Re: BD-RW BDR-208M
nosfrenatu wrote: Mon Mar 09, 2026 7:29 am Hello,
Revision: 1.10
This is a Pioneer. They are not compatible with SDFtool Flasher as it is for the MT1959 drive platform found in LG drives. You should email your info above to Billycar11 for help with the Pioneer.
Re: BD-RW BDR-208M
Revision: 1.10
PM sent.
