maximum lenghts ?
Olaf.
maximum lenghts ?
Post by Olaf. »
System:
makemkv unraid docker & makemkv windows
Hello, is it possible to set a maximum length for titles?
I have TV series DVDs, all episodes of which are also saved as a single MKV file, and I would like to disable this based on the title length.
TIA :-)
Re: maximum lenghts ?
Not within MakeMKV. It's been one of the suggestions for improvement going back a dozen years or so, but the author hasn't expressed any opinion one way or another.
There have been some Blurays where they put entire series (50+ half-hour episodes) in one long file, and you have to use separate programs (like Handbrake or MKVtoolnix) to split them up into individual episodes.
Olaf.
Post by Olaf. »
ok, that's a shame :-(
