MakeMKV rips all episodes as a single large file
comadose
Post by comadose »
I have a particular disc, Spaced season 1, that when I rip it I get a 6GB .mkv file that is the entire season. There are other files which are the extras on the disc.
Is there a way to resolve it automatically?
Re: MakeMKV rips all episodes as a single large file
Post by d00zah »
comadose wrote: Mon Mar 09, 2026 8:32 pm I have a particular disc, Spaced season 1, that when I rip it I get a 6GB .mkv file that is the entire season. There are other files which are the extras on the disc.
Not automatically. MakeMKV works with what was authored on the disc. Most of us have been using MKVToolNix to post-process rips.
https://www.youtube.com/watch?v=Lq_xTWKocOo
comadose
Post by comadose »
Thanks, I'll give that software a try.
And what you receive can vary with the disk set; the series Bleach has several sets, which have different configurations. Some have all episodes as individual files. Some have each disk (5-7 episodes) as one file. Some disks were authored both ways.
At least the Ranma 1/2 disks were all authored the same way, with 7 to 8 episodes per file...
crispgarlic
Post by crispgarlic »
I'm experiencing with most of the Friends DVDs, that MakeMKV is creating a large file with 6 chapters in addition to the individual episodes. This is not consistent though. For instance, Season 2 Discs 1 and 4 have this but DIscs 2 and 3 do not. I've confirmed there are separate files on the DVD but MakeMKV seems to be create the single file most of the time for this series.
So far, MakMKV has created multi-chapter video files (1 per disc, 4 discs), for Seasons 3-8. I'm currently in the process of ripping my Season 7, etc.
Any thoughts? I'm not bothered by it. Should I just keep the single files and not worry about the compiled one and save space?
