Any 3D players out there?
bart1964
Post by bart1964 »
Sorry, not on topic but I'm in a jam.
My Popcorn Hour player's remote died. I can't find a remote to buy so the player is pretty much a brick at this point. Are there any players that can play 3D MKV files and/or a remote that would work with this existing Popcorn Hour player?
Thanks for any help.
Bart
AstralWanderer
Re: Any 3D players out there?
Post by AstralWanderer »
A search for "replacement remote popcorn hour" turned up the following:
https://www.remote-control-world.eu/pop ... rol-p-2637
Hope that helps...
bart1964
Post by bart1964 »
Thanks.
I hadn't considered Europe as an option, but looks like no other options.
Bart
zaqqaz6917
Post by zaqqaz6917 »
If this is a regular ir type remote consider the harmony 700 or 665 programmable by pc ,these are cheap on ebay and are still supported.
If considering harmony, make sure to check their website for the list of still supported remotes.
Their software won't work on non supported remotes
