Pioneer Drives from Aliexpress
boguslecina
#1 Post by boguslecina » Sat Feb 14, 2026 5:52 pm
Hi.
Has anyone bought drives from AliExpress that look like a Pioneer Drive? Are they genuine?
Example:
https://aliexpress.com/item/1005009227614908.html
Re: Pioneer Drives from Aliexpress
#2 Post by Coopervid » Sat Feb 14, 2026 10:04 pm
boguslecina wrote: Sat Feb 14, 2026 5:52 pm Hi.
Example:
Many fakes, be very careful and expect to be scammed.
kaysee
#3 Post by kaysee » Sun Feb 15, 2026 12:04 am
Try asking if they will accept a batch of sealed, expired COVID19 test kits with new fake dates on them for a fake blu-ray drive.
boguslecina
#4 Post by boguslecina » Sun Feb 15, 2026 9:09 am
kaysee wrote: Sun Feb 15, 2026 12:04 am Try asking if they will accept a batch of sealed, expired COVID19 test kits with new fake dates on them for a fake blu-ray drive.
WTF?
boguslecina
#5 Post by boguslecina » Sun Feb 15, 2026 9:11 am
Coopervid wrote: Sat Feb 14, 2026 10:04 pm
Example:
I suspected possible fakes, so I preferred to ask.
zittrig
#6 Post by zittrig » Wed Feb 25, 2026 11:19 am
I risked a Pioneer BDR-UD03 and a LG BU40N in a enclosure.
Both are on it way.
Let's see ....
zittrig
#7 Post by zittrig » Mon Mar 02, 2026 6:42 am
The LG drive in the enclosure arrived.
First check: Contains a BU50N.
Great stuff for 59,99 Euro and shipping takes from February, 23rd to 28th. (shipped to work, so today was the first view)
Next step: awaiting the BDR-UD03 ....
zittrig
#8 Post by zittrig » Thu Mar 05, 2026 5:28 am
The BDR-UD03 arrived yesterday. Works perfectly as an UD04.
Migaman
#9 Post by Migaman » Thu Mar 05, 2026 8:53 am
zittrig wrote: Thu Mar 05, 2026 5:28 am The BDR-UD03 arrived yesterday. Works perfectly as an UD04.
What was the manufacture date on the drives and did they appear to be heavily used?
My main concern with buying these (apart from being fake) would be that they were already heavily used and are close to failing.
zittrig
#10 Post by zittrig » Thu Mar 05, 2026 2:40 pm
Migaman wrote: Thu Mar 05, 2026 8:53 am
My main concern with buying these (apart from being fake) would be that they were already heavily used and are close to failing. T
Mfc was 2018 and it looks like new. But I would doubt that all UD03 from the same supplier will come from the same batch in these days.
AzureVex
#11 Post by AzureVex » Fri Mar 06, 2026 12:46 am
zittrig could you post links to the sellers you bought from?
zittrig
#12 Post by zittrig » Fri Mar 06, 2026 7:22 am
Try it:
BDR-UD03:
https://de.aliexpress.com/item/10050092 ... in_prod%3A
BU40N / BU50N in enclosure:
Can't find the link. Perhaps the seller stopped the offer, sorry.
There are other offer with similar specs, but other sellers.
johannu
#13 Post by johannu » Mon Mar 09, 2026 10:28 am
How to check if a purchased BDR-UD03 from Aliexpress is fake or not?
zittrig
#14 Post by zittrig » Mon Mar 09, 2026 4:20 pm
Ask the seller what you want known e.g..
Then trust or trust not. Try or try not. :wink:
