Hi!
I have a Desktop Tower Chassis (a little bit old but still working) that has a 12,7 mm slot for ODD. But newer ODDs have 9,5 mm thickness.
I want to mount my 9,5 mm ODD into the 12,7 mm slot.
Is there an enclosure or adapter available? I can't find any... sorry
Regards
Johannu
Enclosure or Adapter for 9,5 mm ODD that fits to 12,7 mm Slot
johannu
Re: Enclosure or Adapter for 9,5 mm ODD that fits to 12,7 mm Slot
I'm not aware of a 12.7mm -> 9.5mm adapter, but I am aware of 5.25 adapters.
The ICY DOCK FLEX-FIT Duo MB343SPO lets you put a 3.5" hard drive and a slim ODD into a 5.25" bay.
It is mentioned in this post: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=41108
johannu
@dcoke22: Thank you very much for your reply!
I only have one 5,25" slot in my chassis and this one is already occupied by a 5,25" ODD...
