Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB'
imfergus
#1 Post by imfergus » Mon Mar 16, 2020 4:15 pm
hello all.
i pulled a drive from an old blu-ray player so i could try and rip some blu-rays gifted by someone.
however, makemkv is throwing me errors (as per thread title):
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
dvdfab seems to be able to read the contents fine, and can output, but i would like to use makemkv.
any advice would be greatly appreciated
imfergus
Re: Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB'
#2 Post by imfergus » Thu Apr 02, 2020 11:43 am
anybody?
i searched all i can, but the fact that Dvd-Fab can read the discs implies its not hardware.
BlueMac77
#3 Post by BlueMac77 » Thu Apr 02, 2020 6:13 pm
imfergus wrote: Thu Apr 02, 2020 11:43 am anybody?
Can you indicate what OS are you on and how is your blu-ray connected to your PC. Are you using the latest version of MakeMKV
imfergus
#4 Post by imfergus » Fri Apr 03, 2020 9:13 am
BlueMac77 wrote: Thu Apr 02, 2020 6:13 pm
certainly.
windows 10 version 1909 OS Build 18363.720.
drive has been tried via sata directly, and via a sata-usb adapter (modified to fit the non-standard drive).
MakeMKV Beta Version 1.15.0(x64-release)
also
Ubuntu 18.04.4 LTS
using a usb adapter
MakeMKV v1.15.0 Linux(x64-release) (built following the instructions on this forum)
the drive itself appears to work perfectly since DVD-Fab managed to extract all the files from the blu-ray i ripped, but its done it in a very simplistic way, and its honestly a very clunky piece of software.
BlueMac77
#5 Post by BlueMac77 » Mon Apr 06, 2020 5:20 pm
@iimfergus. Since your using the latest version of MakeMKV, not sure why you’re getting the Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD” Years ago I once encountered a similar Scsi error message, the solution I did was to get a newer version of MakeMKV and that solved the problem. It’s likely the AACS version on the disc is quite new and the old version of MakeMKV app is not updated in reading newer AACS version.
imfergus
#6 Post by imfergus » Sun Apr 12, 2020 1:07 pm
BlueMac77 wrote: Mon Apr 06, 2020 5:20 pm @iimfergus. Since your using the latest version of MakeMKV, not sure why you’re getting the Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD” Years ago I once encountered a similar Scsi error message, the solution I did was to get a newer version of MakeMKV and that solved the problem. It’s likely the AACS version on the disc is quite new and the old version of MakeMKV app is not updated in reading newer AACS version.
it happens whatever blu-ray disc i put into the drive.
i have tried:
District 9
Transformers Revenge of the Fallen
Star Trek II Wrath of khan
and the first one i tried: an anime blu-ray set by the name of "Rokka - Braves of the Six Flowers"
all produce the same result.
i tried testing again, and received this:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:9'
Saved AACS dump file as <user>/.MakeMKV/MKB_v12_Star_Trek_II_The_Wrath_of_Khan_099A.tgz
Grauhaar
#7 Post by Grauhaar » Sun Apr 12, 2020 1:35 pm
Because you have and SCSI Interface protokoll problem, I think the drive from an old Blu-ray payer does not understand the commands.
Good Luck :)
BlueMac77
#8 Post by BlueMac77 » Sun Apr 12, 2020 4:02 pm
imfergus wrote: Sun Apr 12, 2020 1:07 pm it happens whatever blu-ray disc i put into the drive.
i have tried:
District 9
Sorry, I could not think of other possible solutions to your problem. On my end I didn't have major issues with MakeMKV on various optical drive brands. I also have an old Pioneer blu-ray BDR-2007 from 2011 and a Sony DVD 2006 that still works fine with MakeMKV
imfergus
#9 Post by imfergus » Wed Apr 15, 2020 11:53 am
Grauhaar wrote: Sun Apr 12, 2020 1:35 pm
it has a standard sata interface, is read as a standard sata drive, and was able to read the discs with another application (DVD-Fab).
saturn2888
#10 Post by saturn2888 » Tue Apr 04, 2023 3:01 am
I got a bunch of errors just now like this when reading the "Hook" Ultra HD Blu-ray disc. It read the titles just fine though.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8749314048'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '8749314048'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '8749314048'
All of my other discs work fine, but this one does not work. My drives are all ASUS 5.25" USB Blu-ray 16x and flashed with the LG firmware 1.02.
Is it possible this could happen with a counterfeit disc? I just bought a bunch of movies on Amazon yesterday and started ripping them today. "Hook" came in a different-looking black case than the others. The corners are rounder on the right-side of the box. I'm wondering if that's related or if it's just how Tri-star puts out movies.
saturn2888
#11 Post by saturn2888 » Tue Apr 04, 2023 3:14 am
Just noticed this same issue with the Ultra HD Blu-ray of Grease. The Blu-ray seems to be reading fine.
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom2' at offset '7798910976'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '7798910976'
Failed to save title 0 to file G:/Disc-Rips/Grease/Grease_t00.mkv
Not sure what's going on here.
saturn2888
#12 Post by saturn2888 » Tue Apr 04, 2023 3:52 am
Also wasn't able to rip Forrest Gump Ultra HD Blu-ray:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '19674034176'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '19674034176'
Failed to save title 0 to file G:/Disc-Rips/Forrest Gump/Forrest Gump_t00.mkv
kryrano
#13 Post by kryrano » Fri Jan 02, 2026 12:38 am
I'm also getting this error with both Blu ray and 4k UHD of the first Hunger Games
Encode7933
#14 Post by Encode7933 » Sun Mar 08, 2026 4:38 am
This error just occurred to me on Ted Lasso: The Richmond Way in Ultra HD Blu-Ray. The error popped up on the last 2 discs of the collection. Blu-Ray discs can still be read (albeit not well. I have to keep unplugging my unit after every disc to get it to recognise the next disc :roll:). To make matters worse, the previous discs from this set are no longer able to be read by the unit. I really do want to blame my drive. Perhaps it's dying on me?
I have added my drive information and output with debug enabled.
OS device name: /dev/sr0
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLGP37D2009
Highest AACS version: 82
Firmware version: 1.02
MakeMKV v1.18.3 linux(x64-release) started
Debug logging enabled, log will be saved as ../MakeMKV_log.txt
DEBUG: Code 101000192 at u%eo(T'IVrF<)-XT_@:121263429
DEBUG: Code 101000192 at u%eo(T'IVrF<)-XT_@:121262302
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLGP37D2009' at offset '524288'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLGP37D2009' at offset '1048576'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLGP37D2009' at offset '32768'
DEBUG: Code 0 at ~Q4w?( 9{r$"2?#JZf%:121261773
