Romansh
#1
Post
by Romansh » Sat Mar 31, 2012 10:16 pm
MakeMKV v1.7.3 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/tim/MakeMKV_log.txt
Profile parsing error: output format invalid
Failed to load conversion profile from file '/Users/tim/.MakeMKV/profile1.mmcp.xml'
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-8A8 HB14" opened in DASPI v1.3 mode.
I got this error when launching MakeMKV 1.7.3 using my old custom profile. But I also get this error if I replace it with the profile1.mmcp.xml from
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=4386
#2
Post
by mike admin » Sun Apr 01, 2012 12:37 pm
This is expected behavior as updated in sticky post at
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=4386 . Profile syntax changed in 1.7.3 ; if all you care is track selection, then just use default profile that comes with program and set your default selection string in preferences, on advanced tab.
