Problem with Ice Age 3 Blu-ray
hspder
Post by hspder » Fri Nov 27, 2009 9:45 pm
Drive is Lite-on DH-4B1S with Firmware 7P5B (Latest). Works fine with every other Blu-ray I've thrown at it.
Debug log started at Fri Nov 27 21:34:13 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
001012:000000:0020 FAILURE: Code 2 at Rqce;\~Yh3Y}@ZzFx:213130582
001012:000000:0020 FAILURE: Code 0 at TUeJ@pIa_2l,]-8;oi:121261727
001012:000000:0020 FAILURE: Code 1 at TUeJ@pIa_2l,]-8;oi:121261727
001012:000000:0020 FAILURE: Code 2 at TUeJ@pIa_2l,]-8;oi:121261727
001012:000000:0020 FAILURE: Code 3 at TUeJ@pIa_2l,]-8;oi:121261727
001012:000000:0020 FAILURE: Code 4 at TUeJ@pIa_2l,]-8;oi:121261727
001012:000000:0020 FAILURE: Code 2 at Rqce;\~Yh3Y}@ZzFx:29393907
003311:000000:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
001012:000000:0020 FAILURE: Code 0 at h;-E>g)[V-J6xTGB:213131226
001012:000000:0020 FAILURE: Code 0 at h;-E>g)[V-J6xTGB:29396322
005010:000000:0000 Failed to open disc
Re: Problem with Ice Age 3 Blu-ray
Post by mike admin » Mon Nov 30, 2009 8:51 am
Did you insert any other recently released disc in your drive? Can you please share a file named MKB_RO.inf from this disc? It is in AACS directory. Thank you.
hspder
Post by hspder » Mon Nov 30, 2009 3:56 pm
Yes, I have inserted other recent released discs, which did work perfectly. The file you request from the disc is attached (compressed since phpBB would not allow .inf extensions).
Post by mike admin » Wed Dec 02, 2009 8:41 am
hspder wrote:Yes, I have inserted other recent released discs, which did work perfectly.
This MKB looks fine - MakeMKV should have no problem reading this disc. I asked about other discs because of how revocation works - the drive updates itself if it sees a newer disc. So if you just insert a very recent disc the drive will re-flash itself and all previous disc will stop working.
hspder
Post by hspder » Wed Dec 02, 2009 3:36 pm
mike admin wrote: This MKB looks fine - MakeMKV should have no problem reading this disc. I asked about other discs because of how revocation works - the drive updates itself if it sees a newer disc. So if you just insert a very recent disc the drive will re-flash itself and all previous disc will stop working.
Bummer. Is there any way to reverse / circumvent that process?
