Public KeyDB Disc Submissions
BULLBOYKENNELS
Post by BULLBOYKENNELS »
chucky527c wrote:
Thu Mar 05, 2026 1:13 am
Piranha 4K Steelbook (US)
Disc type: UHD
Disc ID: e88eb5e583271bc176408a0e8194b0d93181ee96
Disc dump filename: MKB20_v76_Piranha_4DDF.tgz
Drive: LG WH16NS60
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1vTaaee ... drive_link
Disc dump link: https://drive.google.com/file/d/1l8Sk9E ... drive_link
Seems to be good now at least for me as of this moment, as I had just retried it. On MKB20_v76_PIRANHA_4DDF
Using LibreDrive mode (v02.1 id=DFE22909F92F)
Backing up disc into folder "/Volumes/Samsung SSD 990 PRO 4TB Media/backup/PIRANHA"
Downloading latest HK to /Users/name_here/Library/MakeMKV ...
keydb_helper
Post by keydb_helper »
Thanks to everyone who provided disc dump files. The following new UHD discs have been added to the public keydb:
MKB20_v77_Fast_and_Furious_9463
MKB20_v82_Hereditary_996F
MKB20_v82_Together_7593
MKB20_v82_Battle_of_Britain_UHD (0xFE47498B9FB93BCF9DA5AA5FFA3B5CCEF7AF4A05)
MKB20_v82_KILLERS_OF_THE_FLOWER_MOON (0x7A8F65A2996BD3FE2D7F86F0701E6A646F01202F)
MKB20_v82_THE_BLADE (0xD39DDF3842727CEE675BCF8FE04EEF7C870E45B6)
dheatley96 wrote:
Thu Mar 05, 2026 9:01 pm
Star Wars - The Empire Strikes Back (1980)
Disc type: Blu-ray
Disc ID:0xEE13EEADB49F2B7A81CA6A39C12764BB3DFC305B
Disc dump filename:dump_The_Empire_Strikes_Back_EE13EEADB49F2B7A.tgz
Hey dheatley96, MakeMKV should be able to natively process your disc. Looking at the log file gives some clues:
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDSVM/00004.svm' at offset '8847360'
MakeMKV can't read one of the BD+ files, so it can't mitigate the BD+ protection. All I could suggest is cleaning the disc to resolve the read error.
RogueTetris
Post by RogueTetris »
Dump submitted for Last Action Hero 4K UHD.
Disc type: UHD
Disc ID: 7EA969A56E4CC75EDA8A1B4D3282D65483ACEACE
Disc dump filename: MKB20_v76_Last_Action_Hero_A95F
Drive: BD-RE BU40N
Revision: 1.04
Firmware date: 2120-05-06 11:42
Disc dump link: https://drive.google.com/file/d/1auLzE- ... hVcstjd9e3
Not sure why this one is failing to decrypt, maybe there is a newer version of Last Action Hero on 4K UHD?
On a separate note, has anyone had issues with Bullet Train on 4K? My drive won't even recognize the disc, even though it's brand new and flawless.
JackBurton
Post by JackBurton »
Submitting dump for Arrow's House of Laughing Windows. First time using the forum. Wasn't sure where to find the Disc ID, but if this a necessary piece of info please let me know how to locate it and I'll add it here.
Disc type: Blu-ray
Disc ID: ?
Disc dump filename: MKB_v82_THE_HOUSE_WITH_THE_LAUGHING_WINDOWS_3EAA.tgz
Drive: Pioneer BD-RW BDR-XD05
Drive firmware: 3.10
Disc dump link: https://drive.google.com/file/d/1xgG_NN ... sp=sharing
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_ALL_THE_PRESIDENTS_MEN_0758
*MKB20_v82_Somewhere_in_Time_72BE
*MKB_v82_THE_HOUSE_WITH_THE_LAUGHING_WINDOWS_3EAA
RogueTetris wrote:
Fri Mar 06, 2026 8:41 pm
UHD discs can only be decrypted if they are in the public keydb or MakeMKV's native key database. Until someone provides a disc dump file for their disc it will remain unsupported. It is possible that unsupported titles correspond to new versions, but they can just as easily be older regional variants from smaller markets.
Doesn't sound too flawless to me... All you can do is clean it or try a different drive.
JackBurton wrote:
Fri Mar 06, 2026 9:40 pm
Hey Jack, welcome to the forum. The disc ID isn't absolutely essential, but it allows keydb contributors to quicky check if a disc is already supported by the keydb before downloading and processing the disc dump file.
The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file found inside the AACS folder on your disc. This can be calculated with a tool such as 7-zip or any other good hash utility.
Quarter-Tank
Post by Quarter-Tank »
Disc dump Jason Bourne - Thanks!
Disc type:UHD
Disc ID:0x733E7089938D7175CDBEEF90B2BB2E52C2D8943D
Disc dump filename:MKB20_v61_Jason_Bourne_D0AB
Drive:BD-RW BDR-XD06U
Drive firmware:1.11/ID69
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1Db1PdG ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1EeOXiC ... sp=sharing
Liersi
Post by Liersi »
Disc type: UHD
Disc dump filename: MKB20_v77_TRON_LEGACY_07CB.tgz
Drive: WH16NS60
MKB_RO.inf link: https://mega.nz/file/pwdBka4R#jIR-3ms9s ... hy0tnR9nYo
Disc dump link: https://mega.nz/file/EhMDHJCT#5d7xcAOpm ... Lp9hFQLb84
Thank you guys for the all the time and work you put into this.
keydb_helper
Quarter-Tank wrote:
Sat Mar 07, 2026 1:56 pm
Disc type:UHD
Liersi wrote:
Sat Mar 07, 2026 2:37 pm
Disc type: UHD
Thank you both for the new submissions. Your discs have been added to the public keydb.
If you get a chance Liersi, I'd recommend trying out SamuriHL's KeyDBTool for Windows with your next unsupported disc. It can usually generate and submit keys for discs when the media key is already known to the public keydb - such as your Tron: Legacy disc. You can always post it here if a disc remains unsupported.
kasko
Post by kasko »
Toad King
Post by Toad King »
Disc type: UHD
Disc ID: 09e8d4b2f03fc6717ea14f606421265612b87362
Disc dump filename: MKB20_v82_Boxcar_Bertha_DE43
Drive: BD-RW BDR-S13JX
Drive firmware: 1.03/ID72
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/13qG5-d ... gBlSH/view
Disc dump link: https://drive.google.com/file/d/1rfgDi7 ... G8BmB/view
IdentityTheft
Post by IdentityTheft »
Disc type: UHD
Disc ID: 983188d6bec24e293a64e5cbb5c43ee7c8b48eae
Disc dump filename: MKB20_v82_Five_Nights_at_Freddy's_2_A656
Drive: WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.proton.me/urls/JJ989TCC40#P3hI7Krvvqzz
Disc dump link: https://drive.proton.me/urls/CNCGBGR1CW#SpU7Je4w5HIt
keydb_helper
IdentityTheft wrote:
Sun Mar 08, 2026 12:58 am
Disc type: UHD
Toad King wrote:
Sat Mar 07, 2026 9:20 pm
Disc type: UHD
Thank you both for following the submission template. Your discs have been added to the public keydb.
kasko wrote:
Sat Mar 07, 2026 3:22 pm
MKB20_v82_LETHAL_WEAPON_A65B
Hey kasko, your disc has also been added to the keydb. You were lucky that the media key for your disc was already known to the keydb. Follow the submission template and include the MKB_RO.inf file next time.
albator78
Post by albator78 »
Disc type: UHD
Disc dump filename: MKB20_v82_LesOiesSauvages_F77A.tgz FRENCH
Drive: BW-16D1HT
Disc dump link : https://drive.google.com/file/d/1DivpfM ... sp=sharing
keydb_helper
albator78 wrote:
Sun Mar 08, 2026 12:56 pm
Disc type: UHD
Thanks for the new disc dump albator78. Your disc has been added to the public keydb.
MKVDUDE
Post by MKVDUDE »
Disc type: UHD
Disc dump filename: MKB20_v82_INNERSPACE_0010.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-EaQdCQgXVT
Many thanks!
