Disc type: UHD
Disc ID: 0x973243AE8414E04723642D1E98205912575A9399
Disc dump filename: MKB20_v82_UHD_TGTR_BB37.tgz
Drive: BDR-XS07U
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1BV8Yko ... drive_link
Disc dump link: https://drive.google.com/file/d/1sZLnI_ ... drive_link
Dump Submitted: Together (2025) UHD
keydb_helper
Re: Dump Submitted: Together (2025) UHD
Hey TWBalls, your disc has been added to the public keydb.TWBalls wrote: Sat Feb 28, 2026 10:55 pm Disc type: UHD
Drive: BDR-XS07U
Disc dump files from Pioneer drives are now supported for the purposes of the public keydb. Please post any future disc dumps to the public keydb submission thread (Link).
If you haven't already, you should also email that disc dump file to the MakeMKV team (svq@makemkv.com) so the title can be natively supported by MakeMKV.
Public KeyDB Disc Submissions
Thank you. Yup, emailing makemkv is the first thing I do. I'll have to remember to post in that thread in the future.keydb_helper wrote: Sun Mar 01, 2026 4:04 am Hey TWBalls, your disc has been added to the public keydb.
