I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
I tried flashing the backup to the bu40n mk1.03, firmware. The flash said it succeeded in the sdf tool, but then the drive shows as boot in makemkv and the sdf tool. Once it is in this state, I cannot use it to rip discs (the drive will not even open) and the sdf tool cannot flash it again, but using the LG tool I am able to reflash the original firmware, and the drive works in the sense that it can rip normal blurays, but not 4k.
Is there something I am doing wrong? I successfully flashed my old LG internal drive, but this external verbatim LG bu40n just doesn't seem to want to flash successfully.
Verbatim 43888 LG BU40N flashing failed
boguslecina
Re: Verbatim 43888 LG BU40N flashing failed
Firmware 1.0 may have problems reading and burning certain discs. Versions 1.03 and 1.05 include several fixes that improve stability, especially when burning discs.
Inferno1848
Das gleiche Problem hatte ich auch, dass mein Laufwerk sich die Schublade ebenfalls nicht mehr öffnen ließ.Btags wrote: Sat Mar 07, 2026 5:56 pm I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
Ich konnte bei meinem Laufwerk mit der Original LG Firmware 1.05 selbst damit kein Flashen mehr durchführen, da der SVC Code nicht mehr stimmte, sehe Beitrag 8.
Welches LG Tool ist gemeint?
I had the same problem; my drive's tray wouldn't open anymore.
Even with the original LG firmware 1.05, I couldn't flash it because the SVC code was no longer valid (see post #8).
Which LG tool are you referring to?
I used the "firmware update for bu40n (version 1.05)" tool in the manuals and software tab of the following link:Inferno1848 wrote: Sun Mar 08, 2026 11:22 pmDas gleiche Problem hatte ich auch, dass mein Laufwerk sich die Schublade ebenfalls nicht mehr öffnen ließ.Btags wrote: Sat Mar 07, 2026 5:56 pm I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
https://www.lg.com/us/support/product/lg-BU40N
Also, don't know if it will help you but after many trials I was able to Flash to the 1.04mk firmware for the bu40n and that has allowed me to rip 4ks.
Inferno1848
Also mit dem Firmware tool von LG hatte ich ebenfalls kein Erfolg gehabt, das Laufwerk ging zurück und jetzt hab ich ein neues von Verbatim und dort ist natürlich FW 1.05 drauf.
Jetzt frage ich mir nur welche Firmware ich wirklich am besten nehmen soll, aus welchem Ordner für MakeMKV und DVDFab am besten wäre, ich vermute mal wenn das Laufwerk einen defekt aufweist und man es zurück schickt das dann eine sogenannte Original Firmware drauf ist ein Vorteil ist, also das bei MakeMKV steht - Firmware type: Original (unpatched):
Aus dem All You Need Firmware Pack (MartyMcNuts)
DE_LG_BU40N_1.00.bin
DE_LG_BU40N_1.03_MK.bin
Downgrade Enabled Firmware V.2
DE_LG BU40N_1.00.bin
mk-firmware-pack-20200720 - old
HL-DT-ST-BD-RE_BU40N-1.01-RM00000-211712221221.bin
HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin
mk-firmware-pack-20200720 - HL-DT-ST
BU40N-N-Main - HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
The all you need firmware pack
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Ich möchte nur einmal ein Flash durchführen und das wars, dann pack ich kein SDFtool Flasher oder sonst ein tool mit dem Laufwerk mehr an.
Güße
Und euch allen ein angenehmen Wochenstart
So, I also had no luck with the LG firmware tool, the drive went back, and now I have a new one from Verbatim, which of course has firmware version 1.05 installed.
Now I'm just wondering which firmware I should really use, and which folder would be best for MakeMKV and DVDFab. I suspect that if the drive is defective and you send it back, having the original firmware installed is an advantage, meaning that MakeMKV says - Firmware type: Original (unpatched):
From the All You Need Firmware Pack (MartyMcNuts):
I just want to perform a flash once, and that's it. I won't touch the drive with SDFtool Flasher or any other tool again.
Greetings
And have a pleasant start to the week, everyone!
Güße
Greetings
if you want the widest compatibility go down to 1.00Inferno1848 wrote: Mon Mar 16, 2026 12:03 pm Also mit dem Firmware tool von LG hatte ich ebenfalls kein Erfolg gehabt, das Laufwerk ging zurück und jetzt hab ich ein neues von Verbatim und dort ist natürlich FW 1.05 drauf.
Ich möchte nur einmal ein Flash durchführen und das wars, dann pack ich kein SDFtool Flasher oder sonst ein tool mit dem Laufwerk mehr an.![]()
Güße
I just want to perform a flash once, and that's it. I won't touch the drive with SDFtool Flasher or any other tool again.![]()
Greetings
but you must first flash to 1.03 then go to 1.00
dont try to go to 1.00 directly it wont work
