MKB20_v76_Last_Action_Hero_A95F
*MKB20_v82_ALL_THE_PRESIDENTS_MEN_0758
*MKB20_v82_Somewhere_in_Time_72BE
*MKB_v82_THE_HOUSE_WITH_THE_LAUGHING_WINDOWS_3EAA
UHD discs can only be decrypted if they are in the public keydb or MakeMKV's native key database. Until someone provides a disc dump file for their disc it will remain unsupported. It is possible that unsupported titles correspond to new versions, but they can just as easily be older regional variants from smaller markets.RogueTetris wrote: Fri Mar 06, 2026 8:41 pm Not sure why this one is failing to decrypt, maybe there is a newer version of Last Action Hero on 4K UHD?
Doesn't sound too flawless to me... All you can do is clean it or try a different drive.RogueTetris wrote: Fri Mar 06, 2026 8:41 pm On a separate note, has anyone had issues with Bullet Train on 4K? My drive won't even recognize the disc, even though it's brand new and flawless.
Hey Jack, welcome to the forum. The disc ID isn't absolutely essential, but it allows keydb contributors to quicky check if a disc is already supported by the keydb before downloading and processing the disc dump file.JackBurton wrote: Fri Mar 06, 2026 9:40 pm Submitting dump for Arrow's House of Laughing Windows. First time using the forum. Wasn't sure where to find the Disc ID, but if this a necessary piece of info please let me know how to locate it and I'll add it here.
The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file found inside the AACS folder on your disc. This can be calculated with a tool such as 7-zip or any other good hash utility.
