I'm trying to backup my DVD of Sex And The City and all works well for seasons 2 to 6.
The problem lies with the 2 DVD of the first season. With both I end end up with MakeMKV picking the last title (episode) and skipping the first 5.
Any idea on how to solve this?
Thanks for your support!
Here are the messages from the log :
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Can't locate a cell for VTS 1 TTN 1 PGCN 1 PGN 1
Can't locate a cell for VTS 2 TTN 1 PGCN 3 PGN 1
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 1 chapters
Title #2 (0:26:13) was skipped due to navigation error
Can't locate a cell for VTS 2 TTN 2 PGCN 6 PGN 1
Title #3 (0:24:39) was skipped due to navigation error
Can't locate a cell for VTS 2 TTN 3 PGCN 9 PGN 1
Title #4 (0:23:17) was skipped due to navigation error
Can't locate a cell for VTS 2 TTN 4 PGCN 12 PGN 1
Title #5 (0:23:05) was skipped due to navigation error
Can't locate a cell for VTS 2 TTN 5 PGCN 15 PGN 1
Title #6 (0:24:29) was skipped due to navigation error
Can't locate a cell for VTS 2 TTN 6 PGCN 18 PGN 1
Title #7 was added (1 cell(s), 0:23:07)
Titles not showing - Sex And The City Season 1
morsafr
- Contact:
Re: Titles not showing - Sex And The City Season 1
Please send IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6
morsafr
Done!
Thanks for your support.
morsafr
Any news on this issue ?morsafr wrote:Done!
Thanks again!
